Leaking from coolant crossover pipe
Old Mar 25, 2004 | 07:18 PM
rob2299usa's Avatar
Question Leaking from coolant crossover pipe
My car leaks coolant out of the driver's side coolant crossover pipe connection after trying to fill it after my engine rebuild. I re-used the same pipe and bolts but I installed 4 new rubber washers. Should I put some thread sealant on them and/or should I get a new set?? Thanks for all your help...
Old Mar 26, 2004 | 03:58 PM
rob2299usa's Avatar
Exclamation
I wanna make sure I fix this right so I don't have to do it ever again!!! The GM Service Manual doesn't say anything about thread sealant but I have heard of people using that on the banjo bolts?? What should I do??
Old Mar 26, 2004 | 04:38 PM
Ryans94's Avatar
The same thing happened to me a week ago when I was putting coolant back in after my rebuild. Mine was on the passenger side though. I thought I had tightened it down enough but apparently not. I cleaned the threads on the bolt up with a wire wheel and put it back in with new rubber washers and it stopped leaking. I didnt use any sealer or anything. It sucked to hear the coolant start pouring out on the ground man! It freaked me out for a few seconds Anyway, that is how i fixed mine, hope you get yours taken care of. Good luck.
Old Mar 26, 2004 | 07:36 PM
rob2299usa's Avatar
Alright cool... I'll give that a try. Can anyone tell me what size wrench I'm gonna need for that bolt?? 15mm seems lose and 9/16th's doesn't seem to fit??!!??
calaban
May 18, 2020 06:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
