Leaking coolant
Old May 18, 2003 | 05:27 PM
whiTetAlt1's Avatar
Angry Leaking coolant
It was a hot day here in katy, and i drove for around 20 mintues with the a/c on. While I drive with the a/c on the car temp stays a little over 190 and without the a/c it heats up until the fan comes on. When I was through driving I parked and turned it off. A couple hours later I moved it and saw the orange coolant. I'm wondering why the hell its leaking? I'm about sick of this orange coolant ****, it doesnt even keep my car at a steady temp. What can I do to rid my car of this problem?
Old May 18, 2003 | 05:38 PM
InjectedSS's Avatar
Re: Leaking coolant
wheres the coolant coming from?? gotta get under there and see where its coming from first
Old May 18, 2003 | 09:12 PM
whiTetAlt1's Avatar
ttt, its too dark to look now, any ideas?
Old May 19, 2003 | 09:25 AM
danner's Avatar
could be your weep hole from the bottom of the water pump, if that is the case and left untended, opti is next. good luck
Old May 19, 2003 | 09:28 AM
EviLBoX's Avatar
That's where mine was leaking and I replaced the water pump before it killed the opti. I'd suggest if it is the water pump getting that fixed as soon as possible. First check all the lines though, make sure they're all connected and sealed.
blac94Z
Feb 15, 2021 09:43 PM
calaban
May 18, 2020 06:43 PM
Blood type Z28
Apr 8, 2015 11:34 PM
guitargod33
3rd Gen / L98 Engine Tech
Jul 14, 2002 07:00 PM
vinnyxgunz
Mar 17, 2002 08:59 PM
