Leak @ Oil Fill Tube
I have had a leak at the oil fill tube since the car
was new. It's the plastic extension tube that twists
into the pass side rocker cover. I have tried RTV
and it still leaks. It also seems like this problem got
slightly worse after I installed the 1.6s. Any ideas?
Mine leaked too from where the oil fill neck screwed into the valve cover. I tried RTV a few times...didnt help. Eventually, I replaced my stock valve covers with polished aluminum ones and used the stock Oil cap without the filler tube extension...no more leaks!
ChrisFrez
Feb 22, 2015 08:47 AM
Sandersen511
Jan 13, 2015 03:49 PM
