LE3 Flow Numbers!
Old Dec 30, 2005 | 10:47 PM
  #16
ChrisUlrich's Avatar
Re: LE3 Flow Numbers!
Originally Posted by MEAN LT1
Sounds like your goona have your hands full with that setup.
This is a daily driver too... hahaha
11.9:1 scr (8.1:1 dcr)
I can't wait!! haha
Old Dec 31, 2005 | 12:33 AM
  #17
Zigroid's Avatar
wait till you hear her start up for the first time. your cam specs look to be very close to mine. the sound will be so aurally pleasing you'll never want to go a day without it. to think ive gone 4 weeks without driving/hearing mine . your heads outflow mine in the upper lift range and you have another point of c/r on me. should run really good.
HERES a little preview of what yours should sound similar to
Old Feb 1, 2006 | 04:01 PM
  #18
TransAm396's Avatar
this car sounds ridiculous. Does anyone have a sound clip of the LE2 Cam?
Old Feb 1, 2006 | 05:35 PM
  #19
JustNO's Avatar
Originally Posted by rock1501
those are awesome numbers.
Does anyone know what a pair of AFR 210 comp ported LT4 heads will actually flow.I know the 298/220@.600(FROM AFR WEBSITE) is exagerated a bit.Has anyone here known of any that have been flowed?
I bought a set and am wondering if they will be good enough for my new combo OUT OF THE BOX(SOLIDROLLER 383 WITH A BIG CAM AND A 250 SHOT)
AFR 210cc Comp Ported (just flowed @ThunderRacing. Its a Superflow 1020 bench which gives very conservative numbers)
.200 138.3 / 114.9
.300 192.9 / 164.2
.400 239.7 / 197.8
.500 263.4 / 212.5
.550 273.7 / 217.5
.600 282.7 / 219.7
Old Feb 1, 2006 | 05:39 PM
  #20
JustNO's Avatar
Your cars sound is sooo lumpy! My cam is also similar (240/246) but my lsa is wider (112.7), so I think the sound is different because of that.
Old Feb 2, 2006 | 03:02 AM
  #21
1racerdude's Avatar
487 with the right tune up
Old Feb 2, 2006 | 10:45 AM
  #22
blown383's Avatar
Here are my Lloyd heads from I believe late 2003?
Lift Intake Exhaust
.050 34.5 23.4
.100 62.7 47.7
.150 98.0 74.4
.200 133.2 105.0
.250 165.3 122.5
.300 190.8 140.1
.350 219.0 153.2
.400 237.7 164.6
.450 253.2 173.5
.500 269.4 180.1
.550 273.7 185.1
.600 273.8 188.7
.650 274.3 190.6
.700 273.9 192.1
-B
Old Feb 2, 2006 | 11:13 AM
  #23
Z-RATED94's Avatar
Can I play too? Mine also are from 2003. Before he had stages. Couldn't afford the all out head at the time but did have him put better valves in. He stated that the mid lift numbers turned out pretty good.
.100 65.2 54.1
.200 137.2 109.4
.300 199.0 153.5
.400 241.1 174.1
.500 265.3 185.7
.600 268.8 192.5
.650 269.0 194.2
I wonder if he keeps track of how many sets he has ported so far?
Old Feb 2, 2006 | 01:16 PM
  #24
'94 Bad A Z28's Avatar
Here are some flow numbers for Carter's (for those of you who don't remember he is my local porter/mechanic) Stage 3 heads... stock LT1 castings.
.100 70.5 / 61.4
.200 140.4 / 124.6
.300 206.6 / 180.0
.400 258.1 / 214.2
.500 291.7 / 231.1
.550 294.9 / 236.6
.600 298.8 / 247.5
.650 301.4 / 258.9
Old Feb 2, 2006 | 03:20 PM
  #25
marshall93z's Avatar
I'm skeptical!
Especially about the exhaust numbers!
Old Feb 2, 2006 | 03:31 PM
  #26
Sorry, exhaust had a pipe.
Old Feb 2, 2006 | 03:56 PM
  #27
mourningyou's Avatar
woops, originally posted about a huge runner size but now i see i was wrong. le3 heads > * !
Old Feb 4, 2006 | 01:17 AM
  #28
SStrokerAce's Avatar
Happy bench... you can get either high lift numbers or mid lift numbers or spend a lot of money and time fixing the heads to get both...
.100 70.5 / 61.4
.200 140.4 / 124.6
.300 206.6 / 180.0
.400 258.1 / 214.2
either way I don't think those are happening on a 4.0 bore with the head placed in the right spot on the bore.
Bret
Old Feb 4, 2006 | 01:34 AM
  #29
Cmr0z28's Avatar
I've asked that guy a lot of questions about his heads (Carter)....he said it's a CNC program, and finished up with hand porting. No welding mentioned.
I asked if he would be willing to have them flowed by a 3rd party, and he said no, but I can go watch him flow them. Said he uses an SF600.
I still don't believe it though.
Old Feb 4, 2006 | 01:51 AM
  #30
Yeah BS... If my heads really flowed that I would ship them out and pay to ship them back just for clarification. You know cause flow numbers mean everything. Those heads can move 300cfm, but not without a lot of work.... hell both Lloyd and Phil do a lot of those heads and have played with everything and don't put out 300cfm heads.
Bret
