LE2 and LE3 Inside Here!
Old Nov 21, 2005 | 12:39 PM
Deenasty's Avatar
I am in need, and running out of ideas. Do you folks happen to get split BLM's at idle, due to the amount of overlap of the camshaft? I am having this problem and trying to see if its the "false" lean causing this, or if its just my car. Please give me some feedback. Thanks!
Old Nov 21, 2005 | 01:03 PM
blkchevyz's Avatar
Re: LE2 and LE3 Inside Here!
not sure about those cams, but i have decent size fms cam and i had to tune it in open loop to get it to run well.
my blms would be at 128 but my air fuel ratio with a wide band would read 18-19 to 1
Old Nov 21, 2005 | 01:14 PM
slverbullet's Avatar
what type of TB do you have? also, have you hooked up to a computer and monitored your engine running? if so, is the split blm only at idle or while driving? are the o2 sensors still good? have you swapped them sides to verify that the condition does not follow the plug? do you have any exhaust leaks?
Old Nov 21, 2005 | 01:31 PM
Deenasty's Avatar
So yours run in open loop only? Hows your gas mileage?
Old Nov 21, 2005 | 01:33 PM
Deenasty's Avatar
Its a BBK 58mm tb. I already played with the throttle screw, with no luck. I have everything to monitor my vehicle, and it is only occuring at idle. I believe its a false lean condition only on bank 1. The o2's are brand new, and no exhaust leaks are present, because there is no carbon buildup on anything.
Old Nov 21, 2005 | 01:46 PM
calfirebird's Avatar
My blms were split on mine but it was caused by the MAF sensor. I had a ported and descreened maf and i had to have ed wright fix it with tuning.
Old Nov 21, 2005 | 01:47 PM
how are the IAC passageways on the BBK? any idea if comparable to the AS&M?
check out this link: http://para.noid.org/~lj/PCM%20Tutor...litBLMinfo.htm
interesting info and will further explain the AS&M IAC passageway i was talking about.
Old Nov 21, 2005 | 01:57 PM
Deenasty's Avatar
My MAF is just descreened thats all. If the MAF goes bad, doesnt it shoot a code?
SlverBullet, I am not 100% sure how the passages areon the BBK, but it is worth taking a look at it. Thanks!
Old Nov 21, 2005 | 02:18 PM
blkchevyz's Avatar
yep.
not really sure on the gas mileage, i dont drive the car enough to know.
but i can say is my cam is a little bigger then the 306 and with this tune it has basicly no cam surge
Old Nov 21, 2005 | 03:20 PM
Deenasty's Avatar
well I have tried both open and closed loop, and I feel the car drives better in closed loop. But that could be that my fueling is just off in the open loop tune.
Old Nov 21, 2005 | 03:35 PM
blkchevyz's Avatar
yeah mine was pretty far off in open loop at first... but that was probably due to different injectors and fuel pressure.
have you had any tuning on it yet?
Old Nov 21, 2005 | 03:43 PM
Deenasty's Avatar
I had an open loop tune that I was playing with, and have a wideband in the car, but even at that, sometimes the AF could be wrong. What does your car run at AF wise, idle? Cruise? WOT? I just recently uploaded a PCMFORLESS file, which is a closed loop tune, and im having this issue at idle. I might just go ahead and run a closed loop PE idle tune.
Old Nov 21, 2005 | 04:04 PM
blkchevyz's Avatar
at idle i fattened it up, its around 13.7-14.0
i got the most vacume at that range.
cruise i just shot for 14.7.
wot is 12.9
i put it on the dyno and leaned it to around 13.1 and up and it lost power.
Old Nov 21, 2005 | 04:16 PM
Deenasty's Avatar
wot is 12.9
sent you a PM..
Old Nov 22, 2005 | 01:02 AM
1racerdude's Avatar
If it was the cam overlap wouldn't it do it on both banks????
