LE2 heads rocker studs size
Old Oct 5, 2005 | 12:46 AM
cino's Avatar
I want to buy Pro Magnum 1.6 rockers that will go on the LE2 heads. I don't have the heads yet, but I wanted to purchase the rockers in the meantime. Does anybody know the rocker stud size on LE2 heads. Is it 3/8 or 7/16?
Thanks in advance.
Old Oct 5, 2005 | 12:48 AM
1racerdude's Avatar
Re: LE2 heads rocker studs size
Thanks in advance.
7/16 thread size in the head.Ya can get either stud size.
Old Oct 5, 2005 | 09:42 AM
TQdrivenws6's Avatar
Lloyd doesn't replace the studs, so they have the 7/16 thread in the head, but the stock studs have the 3/8 thread for the rocker mount. So if you don't want to swap out the studs, get the 3/8 rockers. If you are going with NSA rockers, the studs will need to come out regardless to put the guideplates in and at that point most people will spend a little extra for the 7/16 studs and get rockers to match.
Old Oct 5, 2005 | 02:57 PM
cino's Avatar
Thanks. I will go with NSA 7/16 Pro Mags.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
alphaauto
Jan 23, 2015 07:42 AM
95chwagon
Jan 13, 2015 09:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
