LE2 heads just came in flow #'s inside
Old Mar 23, 2007 | 02:20 PM
speed_demon24's Avatar
Before.................................After
.2 132/104..........................2 143/110
.3 186/127..........................3 199/141
.4 226/158..........................4 246/173
.5 243/164..........................5 274/188
.6 238/169...........................6 279/196
.........................................650 282/200
Should have it running this weekend hopefully.
Old Mar 23, 2007 | 02:40 PM
Colin91Z's Avatar
Nice I'm curious to see how much they'll pick up over your old heads...
Old Mar 24, 2007 | 11:07 AM
JP95ZM6's Avatar
Pretty consistant with mine. Your's beat mine at mid lifts where it really helps, but I got a more at high lifts. Mine were done in December 06, so it looks like Lloyd had figured out how to improve mid lift flow even more since then. But maybe this could be within bench-to-bench variation.
Here are the intake numbers (CFM) for my bare LE2 head, head with stock intake, and head with ported intake. Last column is exhaust, head only. Conditions are 28 in H2O, corrected:
Lift.....Bare.....Stock.....Ported....Difference.. ..Exhaust
200....130.9....140.7.....139.8.....-0.9............106.8
250....165.6....167.3.....167.4.....+0.1.......... ..126.4
300....197.7....193.0.....197.5.....+4.5.......... ..141.6
350....224.4....210.3.....219.7.....+9.4.......... ..156.7
400....244.8....230.7.....235.4.....+4.7.......... ..167.4
450....260.5....241.7.....244.8.....+3.1.......... ..175.4
500....274.6....247.9.....254.2.....+6.3.......... ..185.2
550....280.9....254.2.....257.3.....+3.1.......... ..190.0
600....284.0....258.9.....260.5.....+1.6.......... ..193.6
650....289.4....257.3.....263.6.....+6.3.......... ..N/A
More info here: http://web.camaross.com/forums/showthread.php?t=496624
Old Mar 24, 2007 | 11:27 AM
Did Lloyd flow him on his bench too? Eitherway, badass flow #'s do you have any dyno or track #'s?
Old Mar 25, 2007 | 12:15 AM
JP95ZM6's Avatar
No, they were done at Motorcity Muscle (D&S Machine). I was really happy with the flow, too!
Motor still going together, I just got the rest of the $ together so it will be several weeks before VRE finishes my 383 shortblock. Ordered it friday. Then I'll put the car together, debug/tune, and finally run it.
I mostly street drive, but I go to the Milan/Lapeer tracks a few times a year. Street tires, though. I could rarely pull a 2.0 60' on stock motor, and 14.1 at 99ish. So no spectacular numbers to be expected, but I'll share them anyway. I still hope to drop 1.1+ seconds on the motor or I'll be disappointed.
Old Mar 25, 2007 | 07:46 AM
Denny McLain's Avatar
Got to the point were the first thing I look at is how heads flow @ .400. 246cfm from LT1 casting is exceptional. Think those heads are better than you think.......They are capable of quite a bit of power if the rest of your car is done right. I'm honestly impressed.
Old Mar 25, 2007 | 08:58 PM
marshall93z's Avatar
Awesome numbers!
Old Mar 26, 2007 | 04:43 PM
SStrokerAce's Avatar
I've been looking more and more at .200 and .600 numbers, going less on one and more on the other. The midlift numbers just tell you how the chamber shape is, it's that whole 25% of the valve diameter rule.
Bret
Bignasty85
Mar 3, 2015 04:05 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
