LE2.5 & Nitrous
Old Mar 3, 2005 | 06:32 PM
PREDATOR95's Avatar
LE2.5 & Nitrous
How much of a big shot of nitrous will the LE2 cam take. Will it be able to hold a 200 shot of nitrous. This will be on a 355 6"rod with forged pistons & rods with a polished stock crank. The top end will consist of the LE2.5 package. Also will the LE2 cam work good with a vig3000/3.42 gear setup and 26" slick. I appreciate any input you guys might have.
Old Mar 3, 2005 | 07:18 PM
BRENTT94Z's Avatar
Re: LE2.5 & Nitrous
Why dont you just ask Lloyd himself. Hes on the forums quite often, just PM him.
I think he go's by NIGHTTRAIN
Old Mar 3, 2005 | 08:27 PM
Fast Caddie's Avatar
Re: LE2.5 & Nitrous
I'm not sure of the specifics, but i'd run head STUDS instead of bolts and increase the the torque to 10-15lb-ft over the factory ratings for clamping strength with good head gaskets. I can see you making 390-410rwhp NA and 550rwhp+ on a 200 shot well-tuned. You have a killer setup. Plant it to the ground and make the most if it!!! You're looking at mid-low 10s minimum with that kind of power.
Old Mar 3, 2005 | 10:52 PM
SStrokerAce's Avatar
Re: LE2.5 & Nitrous
PREDATOR95,
If you have the LE2 cam in front of you and are wondering this.... yes it will like that much N2O. If you don't have it make sure you tell Lloyd about it and the cam will be changed to make it slightly more N2O happy.
A 3000 stall and a 3.42 gear will work well with that setup, always more gear helps but a 3.42 will do just fine.
Bret
Old Mar 4, 2005 | 08:27 AM
PREDATOR95's Avatar
Re: LE2.5 & Nitrous
Thanks guys for the input I really appreciated.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
