LE2 383 WAY down on power (log inside)
Old Jul 13, 2005 | 10:54 PM
  #16
TQdrivenws6's Avatar
Re: LE2 383 WAY down on power (log inside)
I have replaced the plugs, wires, and O2s now. Here are the new logs, still have the same problem.
Old Jul 13, 2005 | 11:43 PM
  #17
turbo_Z's Avatar
What rec# are you having this problem in the .uni file? At WOT everything looks alright for the most part but whats it feel like? The motor appears to be stalling out just slightly in the upper RPM but thats the only thing that jumps out at me.
Old Aug 4, 2005 | 10:04 AM
  #18
Problem fixed....
I had a dead coil in my Delteq system and 2&3 were not firing. The car feels a 'bit' faster now.
Old Aug 4, 2005 | 12:15 PM
  #19
Cmr0z28's Avatar
Glad you got it fixed!
Old Aug 4, 2005 | 09:46 PM
  #20
94 TA TT2S's Avatar
Where did you get the replacement Coil??????
Old Aug 4, 2005 | 09:49 PM
  #21
94 TA TT2S's Avatar
More importantly how did you figure out it was the coil???? I've had a recent lose in power I pulled the plugs and 2 were soaked , Just wondering what you did....Car doesn't want to idle right either...LMK
Old Aug 5, 2005 | 06:02 AM
  #22
Well it came down to the fact that I knew it was an ignition miss because of how it felt. The shake was violent enough to make the mirrors vibrate as they do in a car with a huge system in it. That was a bit confusing because an ignition miss isn't normally that bad, but mine was. So I pulled all of the plugs, and the #2&3 were looking brand new as if never fired whereas the other 6 looked more normal. The only two things that are common to those two cylinders are the Delteq coil base and the coil itself. So I removed all of the coils and noticed there was a significant rattle in the #2&3 coilpack, so I replaced it, threw in a new set of plugs and there went my problem.
Old Aug 5, 2005 | 07:54 PM
  #23
94 TA TT2S's Avatar
Where did you get the replacement????
Old Aug 6, 2005 | 02:00 AM
  #24
Since I originally ordered my Delteq from Elitesparkplugs.com I contacted them, they warrantied the old one.
Old Aug 7, 2005 | 07:41 PM
  #25
94 TA TT2S's Avatar
Low and behold I did a spark test on my car and in fact my 2-3 coil was not firing....I had a buddy let me borrow one of his coils and it turns out that its not the coil , its gotta be the module the best I can diagnose, I believe I posted earlier that there were 2 plugs that were soaked with fuel from not firing it ws those 2....Not sure that would be warrantied or not guess I need to call him.....
Old Aug 8, 2005 | 06:16 AM
  #26
As long as you are within the original warranty period and contact the retailer you purchased from, I am sure they will give you no issues on replacement. Get ready to ship it out and wait for them to test it though (pretty standard warranty replacement stuff).
carl.froehlich
Mar 13, 2015 12:38 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
NAVY99
Oct 3, 2002 03:47 PM
XtremeLt1
Sep 13, 2002 08:50 PM
