LE2 383 goes 12.18 @ 117.3 2.05 60'
Old Jan 19, 2006 | 09:00 AM
97s10ondubs's Avatar
Still cant get it to hook up on BFG's, time for some ET streets. This is still on the stock 10-bolt by the way w/ 3.42's. Cant wait to go 11's when i get a 12-bolt. The funny part is, this cam was designed for the 350 that was in the car b4, not bad for a cam smaller than a CC306.
Old Jan 19, 2006 | 09:09 AM
Javier97Z28's Avatar
Moderator
Re: LE2 383 goes 12.18 @ 117.3 2.05 60'
Good job man.. I got to see that run too
This wasnt a freak pass either, it also went 12.22 @ 117, 12.25 @ 116.9, and 12.34 @ 116. I wonder what i could do with a dyno tune and some 4.11's.
Old Jan 19, 2006 | 09:15 AM
BlackScreaminMachine's Avatar
Not bad, reminds me of my 383 Hotcam a4 10 bolt 383 doing 12.084 at 113.00. Thats a nice mph, you need to get the 60 foot down, but with a 6 speed, tis going to be tricky.
Old Jan 19, 2006 | 09:16 AM
LT4POWR's Avatar
Old Jan 19, 2006 | 09:17 AM
Yea its all about traction, javier can beat me all night w/ just his cam+stock bottom, his cam is smaller than mine too.
Old Jan 19, 2006 | 09:44 AM
Moderator
not with my broken opti I can't (assuming it's that)
Old Jan 19, 2006 | 10:35 AM
SStrokerAce's Avatar
Dam you guys in Fl! I have to wait for a nice day just to test drive cars with new head/cam installs up here!
Good MPH for that setup!
Bret
Old Jan 19, 2006 | 10:37 AM
yea DA was - all night i believe...-750 at one point
Old Jan 19, 2006 | 10:53 AM
Moderator
I could have run 11's damnit but nooooooo my car had to break
Old Jan 19, 2006 | 03:38 PM
NightTrain66's Avatar
Very good MPH with that mild cam.
as almost anyone that frequents the track will tell you, get that 60 ft down and the car will FLY. Most agree that .10 in the 60 ft is worth .15 in the 1/4 mile. Knock 4 tenths off the 60 ft and you will knock off 6 tenths off of the 1/4 mile ET. If you are having to lift or pedal the car for traction now, there might be even more to gain by launching and being able to keep the car nailed.
Get a 12 bolt and some sticky tires and then launch the car at 4500 RPM (or higher if the tires can handle it) and keep the car nailed the entire pass and you should be able to get a 1.65 60 ft and knock off about 6 tenths from the 1/4 mile ET.
11.70's is more than doable with a good 60 ft.
Lloyd Elliott
972-617-5671
Eportworks.com
Old Jan 19, 2006 | 03:47 PM
marshall93z's Avatar
Old Jan 19, 2006 | 04:25 PM
hvyss's Avatar
Great run for a 2.05 60ft. My Impala ran the same ET of 12.18 on LE2 heads and a Comp 503 on a 355ci but had a 1.66 60ft to get there. My MPH was less 111.52. Had two back runs of 12.21 and 12.23. Cant wait to install the LE cam and hope to get into the 11's N/A at 4400lbs.
HVY SS
Old Jan 19, 2006 | 05:49 PM
neil350's Avatar
Nice, that car has DEEEEEEEEEP 11s in it once that sicty comes down where it needs to be!
Old Jan 19, 2006 | 06:38 PM
ABA383's Avatar
Great mph! FWIW I run 118 and with my good 60's I'm 11.50s...I would expect similar results from you once you get your 60's down....6 tenths is very doable.
--Alan
