LE2 355 finnaly finished
Old Dec 23, 2005 | 02:08 PM
  #16
marshall93z's Avatar
Re: LE2 355 finnaly finished
I went out and took a pic of a starter and some wires that go to it.
Maybe you hooked one of the two grounds on to the starter??
Old Dec 23, 2005 | 02:33 PM
  #17
BlkLT1Z28's Avatar
There should only be two wires going tot he starter, a big and a little red one. There is also a small ground wire that goes to the side of the block in front of the starter. You mifght have hooke that up to it. Im not sure where the ground goes It has been a while since Ive did anything to my car.
Old Dec 23, 2005 | 02:43 PM
  #18
SStrokerAce's Avatar
Originally Posted by marshall93z
So, are you saying that zero lash will be quieter than "some" preload?? Or am I misunderstanding you?
A lot of guys have found it to be that way. The real deal is the valve covers if you want it to be quiet.
Bret
Old Dec 23, 2005 | 03:08 PM
  #19
hallbilly's Avatar
man that sucks... that would make sense now that it was a ground i hooked up to it... there was not a place on the block because i took that factory crap off of it... time to go splice some wires!
Old Dec 23, 2005 | 04:15 PM
  #20
hallbilly's Avatar
LOL... well i found out what really burnt up! The ground wire was just glowing and burnt the coating off of it. What did the main damage was the starter! I believe part of the racket i heard was the starter still stuck engaged. It is broke all to crap on the inside! I shook it hear the loose parts inside rattle and peices fell out of it. The two hot wires that are supposed to go there are fine... the ground is melted all to crap. I should inspect the rest of the wires in the wire harness that touch the ground but im pretty lazy... so i dunno about that one. I would hate to fry something else. Off to autozone!
Old Dec 23, 2005 | 04:57 PM
  #21
LJ93Z28GM's Avatar
That ground goes to a smaller tapped hole in the block, even if you deletd a bunch of crap on the car it will still be there if you are using the stock block.
If you look just below where the lowest head bolts are you will see two holes that you can use, should be toward the middle of the block on a slightly raised section. Then again you also have to find the bolt that was there. I am guessing it is standard since everyother thread going into the block is a standard pitch. Best of luck to ya.
Old Dec 23, 2005 | 07:19 PM
  #22
hallbilly's Avatar
Yup, got it! Thanks guys... my starter was junk so i bought one from checkers... hooked everything back together and voila! problem solved
lesson learned!
Now I can put my tune in and get a sound clip!
Old Dec 23, 2005 | 07:24 PM
  #23
AdioSS's Avatar
West South Central Moderator
so, how does it run?
Old Dec 23, 2005 | 07:26 PM
  #24
hallbilly's Avatar
I havent drove it yet... IM SKURD! nah, i have to clean all the junk out of the seats, check my tranny fluid then pray that God will have mercy on my car... and on the asphalt! lol
Tomorrow I plan to do all of that jazz
'edit oh yea... those things are still noisey... so i guess its the normal noise. When i close my hood you cant really tell
Old Dec 23, 2005 | 07:27 PM
  #25
6SpdLT1Z's Avatar
Post your mods and numbers when you get'r done.
Old Dec 24, 2005 | 09:55 AM
  #26
Loadre's Avatar
Word.
Even though he already fixed it.
Old Dec 24, 2005 | 11:11 AM
  #27
Bret
LOL!! I remember the first time I did mine, they were a little noisy, so I tighten them down even farther!
Old Dec 24, 2005 | 05:49 PM
  #28
hallbilly's Avatar
Hmm... I scanned it with datamaster and im gettin some pretty good knock count. 12 degrees of spark retard with only 11 advanced at some points. When i give it some gas the advance goes up and the retard drops to nothing... is this normal? It still should not be recording that much knock should it?
Old Dec 24, 2005 | 06:12 PM
  #29
Thats a lot of knock retard... which one do you have on the block? LT1 or LT4?
Bret
Old Dec 24, 2005 | 06:34 PM
  #30
Loadre's Avatar
Bret
The one in the block is the same, regardless.
The one in the computer has the choice of being LT1/4.
You are showing that much knock at idle?
