Le1 heads and cam
Old Apr 30, 2006 | 10:49 AM
D.M.F. Solutions's Avatar
Le1 heads and cam
Hi im wondering if i should get some Le1 heads/cam.. if i get the other parts will i be emissions legal still? or could i even go to a le2 heads/cam.
Old Apr 30, 2006 | 11:13 AM
SStrokerAce's Avatar
Re: Le1 heads and cam
The LE1 is not emissions legal unless you get the emissions cam for it. A good combination would be the LE2 heads and the LE emissions cam.
Bret
Old Apr 30, 2006 | 11:14 AM
aboatguy's Avatar
Shoot Lloyd an email with your questions. I know he has an Emmission cam.
Old Apr 30, 2006 | 11:57 AM
Another Red Z's Avatar
Bret
That the combo I am running.I am about 2 weeks away from start up.Still need some small parts to finish it up , but the wallet/CC is screaming .
Old Apr 30, 2006 | 12:59 PM
so go with the le2 with emissions cam.. jw what would that run around then price and hp? beacause i dont see the emissions cam on his website.
Old Apr 30, 2006 | 02:44 PM
NightTrain66's Avatar
all of the cams (LE1, LE1 Emissions, LE2, LE3, etc) all cost the same to produce and the heads are the maindifference in prices of each head and cam package.
We actually do custom cams on each set up for customers but the LE1, 2 and 3 are very common set ups that fit alot of peoples needs. We do not charge anything extra when doing "custom" cams since every one we do is pretty much a custom cam for that set up.
actual dyno #'s will vary depending the rest of the set up but the emissions version of the LE1 cam will be about 10 HP less than the standard LE1 cam. If the car MUST pass emissions, you really have no choice though.
Lloyd
Old Apr 30, 2006 | 03:21 PM
With the LE2 heads it allows us to do more to get you where you want to be in terms of camshaft.
Bret
Old May 1, 2006 | 12:28 PM
scrmnws6's Avatar
Lloyd, that cam that you sent me, is that emissions freindly or not? I do not have to worry about emissions so I would not want to loose out on the 10 hp or so.
Old May 1, 2006 | 02:04 PM
No unless you specifically ask for a emissions cam you get a standard LE cam.
Bret
Old May 1, 2006 | 03:05 PM
scrmnws6's Avatar
Thanks Bret.
Old May 2, 2006 | 12:49 AM
yep, it needs to be asked for or discussed and decided on to get the emissions cam.
I prefer to give the customers thje better performing cam also unless it is just required to pass emissions.
Lloyd
Old May 2, 2006 | 06:43 AM
Lloyd
What makes the cam able to pass emissions.. does it have a smaller lift or something?
Old May 2, 2006 | 08:59 AM
timing events are changed up a lil to reduce the overlap. This will effect how much unburnt fuel the exhaust gets and how well the emissions test comes out. This cam passes pretty easy (about like the CC 305, XE 224/230, etc) and still offers great power.
I have had a few people pass with good "hands on" tuning and the standard LE1 cam although emissions tests are stiffer in some areas and I feel if the car "MUST" pass emissions, it is better to get a cam that WILL pass instead of tryoing to get a slightly larger cam that will "barely pass" but end up "barely failing".
Lloyd
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
