Le1 cam in stock Lt1
Old May 17, 2007 | 10:29 PM
pete foradis's Avatar
I've got a Le1 cam out of my 94 T/A that i don't need anymore, and want to put it in my 95 impala. My question's are
#1 Will it bolt in, or is there to many differences between the heads?
#2 Could i get away with out doing any other mods?
#3 What kind of gains would it have?
I've got 42lbs injectors that i could put in, if it needs it. I plan on tunning computer from pcm forless. Ive spent to much money on the bird so im not going down that road again. I'm willing to buy new spring but that it.
Old May 17, 2007 | 10:35 PM
Wild1's Avatar
I haven't heard of any issues swapping cams with Impalas. You may want to call Lloyd to be sure.
Old May 17, 2007 | 10:44 PM
Dan Parker '96's Avatar
If the springs can handle the lift then it should be okay. I'm not familiar with the LE1 specs so you probably should ask Lloyd.
Old May 20, 2007 | 06:06 PM
sn8ke eatr's Avatar
my only suggestion is if your gonna go though that much to cam it, at least get the major other supporting mods otherwose your gains wont be so great. as for the fuel injectors, i think those are a little to big, i think loyd recomends 30's or something in that area. btw if u dont want the cam, ill take it off your hands
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
