Le1 Cam
Old Aug 1, 2004 | 01:26 PM
Munson's Avatar
Le1 Cam
Anyone know what the lift is on this cam?
Old Aug 1, 2004 | 02:17 PM
TQdrivenws6's Avatar
Re: Le1 Cam
You can get that info when you buy it. But its bigger than the cc305 and lt4 hotcam.
Old Aug 1, 2004 | 02:23 PM
97Z-M6's Avatar
Re: Le1 Cam
no you dont. you do not get a spec card for his cams.
Old Aug 1, 2004 | 02:24 PM
Re: Le1 Cam
Thats interesting, because mine did.
Old Aug 1, 2004 | 02:33 PM
97Z-M6's Avatar
Re: Le1 Cam
well yours slipped by. loyd told me they are taken out, but once in a while one will slip by.
count your self blessed
Old Aug 1, 2004 | 02:37 PM
Re: Le1 Cam
I was also under the impression that once given these specs, they were not to be shared, those of you that have the cam that might want all the numbers on them, feel free to email me and I can list whats on the cam card if you are interested.
Edited due to a deletion
Old Aug 1, 2004 | 02:45 PM
97Z-M6's Avatar
Re: Le1 Cam
I was also under the impression that once given these specs, they were not to be shared, but hey if you choose to do that I guess thats your choice.
the reason i told him. is because he has the cam. so i guees its ok to tell him dont you after all you know dont you.
and acctually i know all the cam specs le1 through le3.
Old Aug 1, 2004 | 02:48 PM
Munson's Avatar
Re: Le1 Cam
how much would it be with 1.7's
Old Aug 1, 2004 | 02:49 PM
Somnambulist's Avatar
Re: Le1 Cam
so do I
Old Aug 1, 2004 | 02:52 PM
97Z-M6's Avatar
Re: Le1 Cam
dont run 1.7rr. the heads good up to a point if you go past that point you get turbulence in the runners and it reduces flow. the cam with 1.6rr is how much it suppose to be run at.
just put 1.6 rr and leave it.
Old Aug 1, 2004 | 02:53 PM
Munson's Avatar
Re: Le1 Cam
alright 97.. i sent you a pm
Old Aug 1, 2004 | 03:07 PM
Re: Le1 Cam
I guess a PM would have been the best way to do it then.
Old Aug 1, 2004 | 03:10 PM
97Z-M6's Avatar
Re: Le1 Cam
sent back
Old Aug 1, 2004 | 03:11 PM
97Z-M6's Avatar
Re: Le1 Cam
now that you say that, i agree.
post deleted
Old Aug 1, 2004 | 04:16 PM
cliff929's Avatar
Re: Le1 Cam
He does not give the cam specs at all? I am going to be spraying nitrous with my setup but was not sure if my cam should be settup to run best on motor rather than the spray as I am not going to spray it every time I make a pass. But my goal is to make it to the 9s
Any ways how will you know what your dcr will be if you dont have the cam specs?
