LE heads & stock cam dyno#s
Old Nov 27, 2004 | 04:56 PM
BeaversTA's Avatar
96 TA A4
My old set up was
k&n cold air, csi pump, lt's, 3"Y dumpt, stock tune, stock cam
285rwhp 309tq
new set up
LE heads, home ported intake, 1.6RR, mac headers and Y thru a 3" flowmaster, k&n cold air, csi pump, Stock Tune, delteq, Stock cam
320rwhp 324tq
The AF set at about 12.2 then droped into the high 11's. The graph is all over the place there is some thing wrong. not to bad thou
Old Nov 27, 2004 | 05:03 PM
madwolf's Avatar
Re: LE heads & stock cam dyno#s
You just need some tuning done for that setup to get the air fuel ratio right and also gain some more HP, but the numbers are not bad either way!
Old Nov 27, 2004 | 06:57 PM
MEAN LT1's Avatar
Not bad at all, thats pretty damn good.
Old Nov 27, 2004 | 07:42 PM
Showme's Avatar
Nice Numbers....
Now go get one of his cams and put a biiiig grin on your face.
Tim
Old Nov 27, 2004 | 08:04 PM
jkipp84's Avatar
Nice! About the same I put down with stock heads and XE 224/230. Excellent numbers for an A4.
Guess this answers that question that comes up every so often - Ported heads and stock cam worth it?
Old Nov 27, 2004 | 08:34 PM
BD380's Avatar
Which heads did you use? LE1, LE2, LE3?
Old Nov 27, 2004 | 08:52 PM
Antz97ZNJ's Avatar
why would you install all that without a cam?
Old Nov 28, 2004 | 02:22 AM
BeaversTA's Avatar
Lloyd didn't have the Le#'s when I got these done. They have larger valves and ported.
Why would I do all this with out putting a cam in? I had a cam in it but took it out when I wrecked my daily driver 01 SS. So I drive this now and purchased a 93 Z with a 355 to play with.
I'm going to start tunning it this week and hope fully can get 330rwhp out of it.
Old Nov 28, 2004 | 02:34 AM
madwolf's Avatar
330 will be no problem.
Old Nov 28, 2004 | 11:35 AM
NightTrain66's Avatar
wow, better #'s than I would have thought.
Lloyd Elliott
NightTrain66@msn.com
Old Nov 28, 2004 | 11:51 AM
97 RedSS's Avatar
Nice sleeper...Now get it tuned and go scare some ls1's...
Cody
Old Nov 28, 2004 | 03:33 PM
BD380's Avatar
What size valves do the heads have? Got any flow numbers? I've been contemplating getting a setup just like that.
Old Nov 28, 2004 | 03:52 PM
dmoor88's Avatar
since the cam is a completely different install from the heads, i dont see why just doing the heads was a bad idea. those numbers look great! get your a/f down, as stated before, and youll see some more nice gains.
Old Nov 28, 2004 | 04:37 PM
blaze309's Avatar
I think with a tune you will be over 330 rwhp.
Make sure you post what you get after you get it tuned im real interested in what you can hit with full bolt on's and a set of heads.
Old Nov 28, 2004 | 04:42 PM
5.0THIS's Avatar
Nice numbers, but I too would have done a cam regardless at the same time.
