LE head porting?
Old Aug 23, 2007 | 06:59 PM
HottestZ28's Avatar
LE head porting?
I have seen a couple threads on LE ported heads an have seen problems where the ports have been cut through bolt holes. My question is what happends when this occurs, when you send your heads to him? Are the heads still good? is there a "garantee" against this or do you have to fix it yourself? I have been awaiting funds to get my LE2 head, cam, intake done and just wanted to make sure of somethings. Thanks
Old Aug 23, 2007 | 07:06 PM
dangalla's Avatar
all that means is that the rocker studs will slightly protrude into the intake ports
simple fix: put some thread sealant on the studs before installing them
Old Aug 23, 2007 | 07:29 PM
wrd1972's Avatar
This is not an issue.
Old Aug 23, 2007 | 10:03 PM
HottestZ28's Avatar
what part? explain please?
Old Aug 23, 2007 | 10:16 PM
bdc95ta's Avatar
the holes I got em in my LE3's, just use sealent on the ones that need it.
-b
Old Aug 24, 2007 | 12:02 AM
SS MPSTR's Avatar
correct. no big deal at all.
Old Aug 24, 2007 | 08:42 AM
wrd1972's Avatar
The holes in the intake runners.
Old Aug 24, 2007 | 09:41 AM
Z-RATED94's Avatar
Refer back to post #5. This is a very common thing.
Old Aug 24, 2007 | 10:57 AM
White96Z28's Avatar
It's not just LE heads... Any stock casting that has a full port job will have the same issue, but as long as the flow numbers are good, and consistant, it's not a problem.
oldschool
Feb 9, 2016 09:21 PM
Dmonty
Jun 2, 2015 11:19 PM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
Killer94z
Jan 13, 2015 12:06 PM
