LCA relocation after SFC install?
Old May 14, 2003 | 08:57 AM
Russtebo's Avatar
Is there any issue with installing LCA relocation brackets AFTER installing KBDD SFC's? I hope to get my SFC's on this weekend but in mocking it up last night I had the concern that they may somehow interfere with the relocation brackets (when I finally end up getting them). Any thoughts/suggestions? Thanks for your help!
Old May 14, 2003 | 11:31 AM
norcalstreet's Avatar
There shouldn't be any problems. The subframe connectors keep the control arms in the stock location from what I recall. A relocation bracket shouldn't have any effect on it.
Old May 14, 2003 | 12:05 PM
The LCA relocation brackets mount to the axle assembly end, not to the subframe end. Brackets are nowhere near the SFC's, and the SFC's should not in any way restrict the ability of the LCA to swing in an arc about the bolt on the subframe end.
Old May 14, 2003 | 03:02 PM
chesee48's Avatar
I had no problems with my KBDD SFC and my re-location brackets. You should be otay!
Old May 14, 2003 | 04:28 PM
JSK333's Avatar
Ditto, no problems with KBDDs and relocators. They both tie into the frame of course, but not at the same point.
Old May 15, 2003 | 02:24 PM
Russtebo's Avatar
Cool. Thanks guys! I thought the relocation brackets went in on the frame side. I learned something new today, now I can go home!!
Nov 18, 2023 07:21 PM
94B&RZ-28
Dec 22, 2008 10:00 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
