Last thoughts before button up...
OK guys, I need some final thoughts before I finish this car up.
I just replaced the opti and made sure the splines were matched up. I made sure all the new plug wires were routed to the correct places and plugged all connections on the opti. I replaced the oil pressure indicator and oil level sensor (both were broken) and plugged them back up. I filled the engine with new oil and replaced filter. When I replaced the water pump I put new paper gaskets on (I did not put any silicone on the gaskets) and tightened all 6 bolts so they were nice and tight. I connected all the water hoses back to the pump and am getting ready to filler the coolant up and put the fans back in place.
After all the work I did I cant help but feel like I missed something or did something wrong. Can you guys please take what you learned from your experience with this kind of job and let me know. Im afraid of filling everything back up and putting the rest together only to find out I missed something or did something wrong.
Sorry this is so long but I appreciate your thoughts on this.
Matt
Matt
Thanks guys!
I quit being a baby about it and just filled her up and started it. Surprisingly it started and idled pretty good, no leaks as far as I can tell so tomorrow I will take it for a test drive and see if the problem is fixed and make sure I didn’t create any other problems.
If all goes well I will post a new post with links to the problems I was having so someone can use what I learned and save themselves some time and money trouble shooting. Like I said, if all goes well...
Thanks Hal. I am pretty sure that piece stayed connected to either the block or the WP when I disassembled. The splined shaft seemed to fit back into place the same as when I removed the pump.
BTW, for anyone watching this thread, I may not get to test drive the car today unless the thunderstorms stop.
guruerror
Jun 9, 2015 07:41 AM
