l98 vs lt1 weight
Old Apr 20, 2003 | 03:46 PM
lt4 fd's Avatar
l98 vs lt1 weight
I know the lt1 weighs about 520 with all accesories and what not, but how much does an l98 weigh?
Old Apr 20, 2003 | 07:02 PM
Josh-'04 GTO's Avatar
I would say about 40 lbs more due to the iron heads on an L98. Other than that, I wouldn't guess much of a difference.
Old Apr 20, 2003 | 08:59 PM
lt4 fd's Avatar
? I thought they had aluminum heads..or was that just the vettes? Anyone know for sure what they weigh?
Old Apr 20, 2003 | 09:02 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
just vettes
they may weigh a bit more because their air pump was with a pully, we have light weight pistons, opti is a bit lighter, ect
Old Apr 20, 2003 | 09:07 PM
mr diabolical's Avatar
i have a shipping receipt for a ZZ4 somewhere that probably has the wieght on it. its pretty much a aluminum headed L98. stock fbody L98s had iron heads, stock mid 86-91 vette L98s had aluminum.
Old Apr 20, 2003 | 09:26 PM
lt4 fd's Avatar
Post it if you can I am looking at the weight of heh vette l98's, Thanks!
Old Apr 21, 2003 | 02:40 PM
onebadponcho's Avatar
I have a book at home that has that info in it; unfortunately, I'm at sea right now so I can't look this up again. However, if I'm not mistaken, it said that the L98 is about 20lbs lighter than the LT1; and I'm assuming both had the aluminum heads for the measurement.
Old Apr 21, 2003 | 02:42 PM
IrocManiac's Avatar
Do the F body LT1's have alluminum heads?
Old Apr 21, 2003 | 02:46 PM
it was 490lbs with no intake
Old Apr 21, 2003 | 02:58 PM
CamaroBoy96Z28's Avatar
Yup, F-car LT1s have Al. heads
Old Apr 21, 2003 | 03:01 PM
treyZ28's Avatar
WHOA!
thats alot. The block itself is only like 146 lbs or somethign. Crank rods and alum heads weigh 300 lbs>?
Old Apr 21, 2003 | 04:19 PM
it had a waterpump, flywheel, dampner, alt, pwr steering pump, ac comp, tensioner, and a air pump /w brackets. plus they left the belt on so that added a good half a pound
Old Apr 21, 2003 | 04:36 PM
Dr.Mudge's Avatar
I've heard the figure as low as 450# for an early L98, who knows if that is all inclusive though.
Old Apr 21, 2003 | 05:18 PM
i think the zz4 might have had a different crank.
Old Apr 21, 2003 | 09:46 PM
lt4 fd's Avatar
how much the intake weight? hehe
