L98 to LT1 swap help
Old Mar 3, 2008 | 10:02 PM
frankensteingta's Avatar
Does anyone know of a good step by step guide for swapping out a L98 for a LT1?
Thanks.
Old Mar 3, 2008 | 11:09 PM
JD311's Avatar
Should bolt in no problem. I believe there is more info in the 3rd gen section regarding wiring and such.
Old Mar 4, 2008 | 06:58 AM
2000GTP's Avatar
Are you swapping in the wiring harness/PCM and tranny as well, or just strictly the engine?
Old Mar 4, 2008 | 04:42 PM
DrummerDad's Avatar
Go to thirdgen.org. They have a complete section on it, and several members that have done the swap, and help with harnesses, and ECMs, fuel lines etc.. Im currently in the middle of buying for my swap, which should happen next year.
Its not as easy as a drop in, but nowhere near as bad as an LS1 swap. PM me if you have more questions.
Old Mar 5, 2008 | 08:28 PM
L98 to LT1 swap
Thanks for the help guys. Will do more searching on 3rdgen.
As for what all is getting swapped, i have the LT1 engine and the computer but thats it.
Will probably purchase the Painless wiring harness due to not being a electronics wizard.
Hope to keep the stock transmission (700r4?)
Old Mar 6, 2008 | 04:29 PM
DrummerDad's Avatar
Let me save you a little trouble now. Ive been buying parts for weeks, and doing alot of research.
700r. It will work, but its a PITA. The kickdown cable wont work with your LT1, and Im sure the speedo wont work like it is either. Again, read over at thirdgen.org. Its better to go with a 4L60E. I bought mine rebuilt from a local shop for $550, with a new stock converter.
Dont waste youre money on a painless kit. Go to thirdgen, and go into the engine swap section. A member named Z28ricer is making a harness for me. Tell him I sent you to him (same user name there also). Mine is still being made, but Ill post pictures when it gets here. Hes also programming an ECM for me.
And your fuel pump will work, for now. If you plan on doing any kind of work, youll need to upgrade.
There are more things to consider. Power steering, A/C location and lines, fuel lines, dual fans if you dont already have them. Read up. And good luck.
Noer
Feb 28, 2015 11:29 AM
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
