L98 heads on a LT1
Old Jan 18, 2005 | 12:02 AM
79TTCAMARO's Avatar
L98 heads on a LT1
I have been doing some research online, and I have found that people have successfuly bolted lt1 heads onto an l98 and early style sbc's. Can this be done in reverse and has anyone done it?
I have a set of fully ported sportsman ll heads that came off my last drag motor. They are good for high 10s low 11s all motor....so I was thinking if there is anyway that I can get these heads to fit on my car...I want to do it.
Any info is welcomed! Thanks
Old Jan 18, 2005 | 12:05 AM
indieaz's Avatar
Re: L98 heads on a LT1
reverse flow cooling design isn't going to allow this. For the same reason you can't bolt standard SBC heads onto an LT-1.
Old Jan 18, 2005 | 12:10 AM
79TTCAMARO's Avatar
Check out yahoo...people are putting lt1 heads on old small blocks and making it work.....I wants to put old heads on an lt1.
Old Jan 18, 2005 | 12:14 AM
Bawls's Avatar
Yeah you can put LT1 heads on standard SBC's just have to weld some ports shut. However the other way around wont work since you would have to drill/port for the reverse cooling design to flow through the heads.
Old Jan 18, 2005 | 12:18 AM
79TTCAMARO's Avatar
Dam! Thats what I thought the answer was going to be. Thanks for the info though!!
Old Jan 18, 2005 | 12:26 AM
Bawls's Avatar
Yeah, That's unfortunate sounds like you've got a pretty sweet set of heads there.
Old Jan 18, 2005 | 06:55 AM
dhirocz's Avatar
Why couldn't you? You could drill the reverse coolant holes in the decks, drill and tap the back of the heads for the steam tube, and either use a different intake or modify the heads for the LT1 intake pattern. It's been done...it just takes some work and research. I know I did some LT1 heads for an L98 that came out ok so I dont see why you couldn't do it the other way around.
Old Jan 18, 2005 | 07:00 AM
Soccerbum21's Avatar
the whole reverse flow thing might make it too expensive to to machine to even bother...unless you DIY it
Old Jan 18, 2005 | 07:17 AM
It's a lot easier to plug some holes than it is to make passages that were never cast there in the first place.
Old Jan 18, 2005 | 10:38 AM
dhirocz's Avatar
True. I guess it depends alot on the cylinder head and the person doing the work.
Old Jan 18, 2005 | 06:35 PM
96capricemgr's Avatar
A vendor on ls1tech.com recently posted about charging $500 to convert gen1 heads for LT1 use.
When I first saw the topic I about choked because stock L98 heads flow 15% LESS than the iron LT1 heads or the 96-7 aluminums so even ported those would have been a waste of effort.
Old Jan 19, 2005 | 01:11 AM
79TTCAMARO's Avatar
I have heard of l98 heads on a lt1 too. It might be expensive...but if it works, it would deff be worth bolting up a set of 3000$ 18 degree heads where you could easily make 750-800hp, all motor. I would have to buy aftermarket lt1 heads plus put atleast 1000 into porting them to even come close to my l98 heads. . 500$ I would pay any day of the week.
Could you point me in the right direction on what topic to go under inorder to find that guy that will convert them? I would really appreciate it.
Old Jan 19, 2005 | 07:19 AM
dhirocz's Avatar
I really dont see what could be so hard...given that all heads are different, but anyone should be able to take a nice set of 18 degree heads and pop them into an LT1. Problem for me is I dont know of any small chamber high-flow 18 degree heads. A buddy of mine had some brodix 18 degree heads I was thinking of trying that on...anything's possible. I bolted an optispark on a 400 SBC just to prove it could be done so I'm sure the heads aint $hit.
Old Jan 19, 2005 | 09:00 AM
Zepher's Avatar
You could slap a regular sbc in there, have the LT1 intake modded to bolt to the sbc heads, have a machine shop fab up a timing cover that allows you to bolt on the opti, run an electric waterpump and be done with it.
Old Jan 19, 2005 | 05:07 PM
dhirocz's Avatar
Been there, done that. Takes a little more work than that...but it's doable. The waterpump is also a PITA to deal with since you need clearance for the optispark when using a gen 1 small block and even more of a pain if your rotating assembly isn't internally balanced. This is one of my little projects right now...
