Knocking sounds in my back end Help!!
Old May 30, 2003 | 06:35 PM
97BBlackZ's Avatar
Theres a knocking in the back of my car i doticed it sence we got it back from the dealership. It doesnt happened all the time but like on turns i notice it when i apply throttle and it sounds like a thonk sound in the back right wheel atleast thats were it sounds like its coming from. It did it to when i romped it.... What could this be?
Old May 30, 2003 | 09:03 PM
97BBlackZ's Avatar
car is a 97 Z28 BTW
Old May 31, 2003 | 02:05 AM
CrippleFightin's Avatar
trans mount maybe....
Old May 31, 2003 | 02:29 AM
fbird95's Avatar
I would say trans mount is old and mushy if not busted, or if that is intact, panhard bar bushings maybe.
Old May 31, 2003 | 08:26 AM
97BBlackZ's Avatar
So how hard is that to fix and how much might it cost? I think i read somewhere that its 40 buck to 20 bucks for the part... is that right?
Old May 31, 2003 | 10:09 AM
Jay-Roll's Avatar
I bought a Poly ES trans mount from Internet Racers Supply for like $25 bucks. It's very easy to install. I did it during a trans swap but yours will be the same way. All you need to do is just get a little floor jack(or even a block of wood or something) and put it up at the rear of the trans to stop it from hanging down when the crossmember is removed. I'm not sure that it hanging would cause any damage anyways but it just made me feel safer. Then there's just 4 bolts holding up the crossmember, two on each side. Take those off and the crossM will come right off. The Trans mount is mounted on that with 4 little bolts I think(can't remember for sure). Take the old one off and put the new one on with all the supplied hardware and reverse all the steps. I don't remember how detailed that info is, but you would have figured out how to do it on your own anywayz. Good luck
Old May 31, 2003 | 10:33 AM
DarkHorse's Avatar
What did you have done at the dealership?
Old May 31, 2003 | 10:39 AM
z28jaz's Avatar
If it's not the trans mount, you might want to make sure the spare tire is tightened down properly... mine wasn't when I got the car and it made some similar noise.
Old May 31, 2003 | 10:52 AM
97BBlackZ's Avatar
We had then put in a new water pump and a new servintine belt (not quite sure how you spell it)
Old Jun 1, 2003 | 07:45 PM
97BBlackZ's Avatar
Got some mroe info
When i floored it today it make the knocking sounds twice inbetween shifts like it was go to shift then go knock knock then go into another gear as far as i know it did that everytime it shifted
Old Jun 2, 2003 | 07:43 PM
Tires_Smokin's Avatar
Yep, tranny mount! Happends all the time......
F'n1996Z28SS
Aug 23, 2023 11:19 PM
vb95z28conv
Jan 27, 2015 08:32 AM
Collector Car
Jan 5, 2015 10:58 AM
jayblev95
Dec 1, 2014 06:55 AM
