knocking or clanging noise?
well my 95 t/a has a new 383 with around 600 miles on motor. has scat forged rods and crank, trw pistons, 4 bolt main, le3 heads, comp r lifters, comp cams 468 cam, crane fireball, msd coil and wires, electric w/pump, l/t's, 3" o/r y-pipe, gmmg catback, 2400 stall. well i drove it easily for miles then the opti's rotor button shattered. well i replaced it took it out for a drive and decided to get on it. im running motorsport z06 wheels 18 rear 17 front. it wouldnt keep traction. well on the wat up my road when i did it and let off the gas it stalled out. i started it back up it stalled then it started up and would stay running if i was on the gas but would make a knocking clanging noise all the time no matter what, even whit the coil unpluggedjust spinning over. its extremmely loud. pulled valve covers and everything looks good, pulled the oil pan and bearings looked good but changed them anyways. any ideas? oil pressure is good while on the gas dont know about at idle because it wont. the nite before when running with new opti i reved it several times but didnt start doing it until i got on it driving. its driving me nutts because i have spent so much on it for it to be doing this.
autoxr166
Sep 25, 2015 04:21 PM
