knock sensor bypass...
is there a way to bypass the knock sensor (i know i know... Why)
well its giving me KN retard from the vibration of the motor, just want to bypass to test something...
Just curious since the traction control will pull timing also. I wonder how many people have a problem with the traction system pulling timing through a faulty connection to the PCM?
So why do you think your engine is vibrating? You didn't install solid motor mounts did you?
Originally posted by VIPRETR
On my 96 Formula I just unplugged it. Never had any ill effects. I know some peole say it will pull timing if unhooked but mine never did.
Originally posted by shoebox
Did you verify that with some data logging? Just curious.
14
Aug 11, 2015 12:03 PM
Noct
Jul 14, 2015 01:18 AM
