Knock Readings?
Old Jun 29, 2004 | 06:30 PM
ChevyIron's Avatar
Knock Readings?
Finally getting around to start up my new motor,well when I started it my scanmaster at idle said I had 1.5 knock Is that bad?What should be a accecptable level of knock and what is dangerous level of knok?Thanx in advane
Old Jun 29, 2004 | 06:55 PM
If you are seeing a constant 1.5° of knock retard, it is picking up something (could be just excess noise). The computer is reducing the advance by 1.5°. Other factors could be if that is just too much timing for your setup (if it has been reprogrammed) or you might have a lean condition.
Old Jun 29, 2004 | 07:18 PM
ChevyIron's Avatar
Thank you Rob the car was reprogrammed for my setup.But is 1.5 alot to see just at idle?
David
Old Jun 29, 2004 | 09:38 PM
IMO, there really should be no reason to be getting knock retard at idle.
BigWil
Mar 29, 2015 12:24 PM
4586
Mar 18, 2015 06:31 PM
HectorM52
Mar 15, 2015 10:45 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
