Knock Readings?
Knock Readings?
Finally getting around to start up my new motor,well when I started it my scanmaster at idle said I had 1.5 knock Is that bad?What should be a accecptable level of knock and what is dangerous level of knok?Thanx in advane
If you are seeing a constant 1.5° of knock retard, it is picking up something (could be just excess noise). The computer is reducing the advance by 1.5°. Other factors could be if that is just too much timing for your setup (if it has been reprogrammed) or you might have a lean condition.
z28projects4ever
9
Jul 16, 2002 07:48 PM
