knock question
I over rev'd engine ,collapsed a lifter ,motor began to knock at about 2000 rpm,when idling motor does not knock but oil pressure drops to almost zero & low oil light comes on , when starting motor it knocks bad for about 5 sec.replaced lifter still does same thing.Could it be cam bearings?
Re: knock question
Originally Posted by gillt1
Thanks shoebox,but my buddy and myself listened to bottom end with screwdiver on oil pan & block while rveing motor & sound is up top Thanks again.
Re: knock question
This one I can answer bu personal experience! I am actually in the process of rebuilding my engine right now. I had a knock that sounded like valvetrain noise and after repeated valve adjustments and having the intake off numerous times replacing the lifters (all of them) I decided it was time to pull the engine. I got it out last night and I had smoked all of the bearings. No sh*t, ALL of them!!!! Looks like a main baering went bad and sent particles all through the bottom end wasting all the other bearings. I'm going to have to do the rod, main and cam bearings. Weird thing is, i had about 5 different people listen to it and everyone thought it was in the valvetrain. I replaces all aftermarket parts in the valvetrain with stock (known good) parts and it was still there. We started by taking off the heads and everything looked good.......so out the engine came. Not to try and make your problem sound worse than it might be, but................might be bearings!
