Knock Module Questions
Old Nov 26, 2006 | 08:12 PM
lt1 kenobi's Avatar
Ok , I know what the module does.... however I read that if you put longtubes on and they hit the floor of your car that the module may mistake that for knock and start pulling timing. I have a 94 z28 and sometimes my lt's do hit the floor... Would an lt4 knock module solve this problem??
Old Nov 26, 2006 | 08:18 PM
OBE1 95Z28's Avatar
Your car has both a knock sensor (microphone) that screwed into the block and a knock module (filter circuit) that mounts onto the PCM. The knock sensor picks up mechanical noises made by the engine and sends them to the PCM, going through the knock module. The circuit is "listening" for engine knock and can be fooled by mechancial noises like banging headers. The LT4 knock sensor was "tuned" to ignore the valve train noises made by the RR's that came standard on the LT4 engine. Chances are the LT4 knock module won't help you with banging header noises.
MadMav
May 25, 2015 09:35 PM
HectorM52
Mar 15, 2015 10:45 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
SC97TA
Sep 15, 2002 01:10 AM
