knock mod help
Re: knock mod help
The knock module is a noise filter. The LT4 knock module was specifically tuned to block the noise signature from the Crane Gold roller rockers used in the LT4 engine, to prevent knock retard due to "false" knock.
Re: knock mod help
well, your car will most likely Burst into Flames upon switching to the LT4 knock module...
just kidding,
Most people on this board are running the LT4 knock module with various LT1 setups, it will help the computer filter out noise from a loud exhaust/cutout, headers, roller rockers, etc, etc
just kidding,
Re: knock mod help
Its a simple filter. Its effectiveness on noises it was not designed to filter is debatable. It is not a cure-all for knock problems, false knock problems, banging exhaust systems, etc.
Re: knock mod help
Originally Posted by bowtiepwr
>well you could always "Desensitze" you PCM. not recommended, but doable.
Re: knock mod help
Originally Posted by 00JoeZ28
What would happen then if I were to put an LT4 knock module on an 355 Lt1 with ported heads with 1.6 roller rockers? Non crane golds.
Time would stand still..
get the car up and running...then worry about the tune....
.....and the Patriot Red Z, cause you are going to need 8lbs per min of n2o to even see the side of her door
HA HA HA
