Keyless entry controller...
Old Dec 30, 2003 | 11:12 AM
Myxtreme1's Avatar
Ok, I had to put new batteries in my keyless entry controller (or fob I guess it's called) and I was wondering does it need to be reprogrammed? I had to do the same thing on the Blazer. Do I just take it back to the dealer or what? Thanks!
Old Dec 30, 2003 | 11:29 AM
Red96Lt1's Avatar
The dealer can program it. I've ran across something that said that the average person could program it though.
Old Dec 30, 2003 | 11:49 AM
ibanez6rg's Avatar
You don't need to take it to a dealer. It's as easy as getting a fused wire and connecting them to 2 points on your ALDL connector.
Old Dec 30, 2003 | 11:51 AM
Chevycobb's Avatar
I know on OBD1 you connect a fused wire to terminals A(bottomg far left), and G (top far right) when you do that you should hear the, lock and unlock. then when you hear that push a button on the remote and they should lock and unlock again telling it accepted the code. remove the fused wire and you're good to go...not sure on your 2000 blazer because it's OBD2...i'll see if I can find out for ya if no one chimes in before I do
EDIT: check the manual if you still have it, it should tell ya
Old Dec 30, 2003 | 12:37 PM
TechnoThief's Avatar
Go to http://www.installuniversity.com/ins...ar/key_fob.htm , he has the proceedure for reprogramming the FOB. It's also listed in the users manual if you have it handy.
Old Dec 30, 2003 | 12:47 PM
Myxtreme1's Avatar
Thanks I'm gonna look through that!
Old Dec 30, 2003 | 07:05 PM
Mtrhds94Z's Avatar
Well the KEY answer here is.. no you don't need to reprogram after just changing the battery...
Old Dec 30, 2003 | 07:35 PM
Chevycobb's Avatar
i needed to reprogram after replacing my battery
Old Dec 30, 2003 | 07:45 PM
Mtrhds94Z's Avatar
I didn't, and have done it several times...
Only time I had to 'reprogram' mine was when I bought a used FOB when one stopped working..
I guess the answer is, that if a battery change didn't work, try to reprogram it?
And yes, it can be done by oneself, no need for dealer to get involved...
Remember to do both fobs if you do reprogram them...
And the 'early' fobs have a different procedure than the 'late' ones..
Old Dec 30, 2003 | 08:28 PM
Myxtreme1's Avatar
What is the procedure for mine? '94 model?
Old Dec 30, 2003 | 08:36 PM
Myxtreme1's Avatar
got it
http://shbox.com/1/4th_gen_tech2.html
Old Dec 31, 2003 | 06:17 AM
Mtrhds94Z's Avatar
Re: got it
Yes thats it...
Old Dec 31, 2003 | 08:37 AM
There should be no reason to have to reprogram after changing the battery in the fob. The programming procedure allows the receiver to adapt/match the fob. The frequency that is output by the fob cannot be altered, so just changing the battery cannot affect it.
Old Dec 31, 2003 | 08:45 AM
Pandamonkey's Avatar
This is great!
I myself just picked up an addtional key fob.
Perfect timing.
Old Dec 31, 2003 | 08:46 AM
Myxtreme1's Avatar
hmmm, I wonder why mine isn't working on my car. Could my fob be bad? Can I get one off of ebay and use it or is that not possible?
