keyless entry alarm question
Old Jun 16, 2003 | 11:19 PM
ponykiller z28's Avatar
Angry keyless entry alarm question
ok i've got a question about my factory keyless entry/alarm. I've re programmed my transmitter and have read up on everything there is to know about it in the manual, including all the special features (last door lock, etc) and have disconnected the battery ...but still.........
here's what happens...... everytime i arm my car from the outside (the car horn chirps twice) and about five or six seconds later it starts going off for no reason. every single time. i've checked the sensitivity of the shock sensor and it's set normal. I have tried everything and i do not know what to do.
If anyone has had this problem PLEASE help me out and give me some suggestions
THANKS FOR REPLIES
Old Jun 17, 2003 | 12:03 AM
CrippleFightin's Avatar
Not sure what the problem is, but my lights open up on my T/A when i hit the panic button.....hmmmm, Cant figure that out either. Good luck with it though.
Old Oct 7, 2003 | 01:15 PM
Oxygen454's Avatar
Angry Alarm Problem
Hey buddy I have the exact same problem. My car had some minor damage to it so I got it fixed and painted. I took my car home and about three days later I started having the same problems. Arm the car and about 6 secounds later if not less the alarm goes off again.
I unhooked my sensor and the alarm stopped going off. I kinda cleaned the terminals but I am going to try and clean them better. Bad area to get into on that kind of plug. I also opened my trunk and the seal wasent properly covering and I think the water soaked it so that might be why. I tried drying it out but so far no luck. I just want to throw the stupid thing lol
So yeah its still not working right what can I do?
HELP!
Old Oct 7, 2003 | 04:14 PM
siberiankiss's Avatar
my car started doing that after i got in an accident...the little thing that pushes in when you close the door was broken...can't think of anything to call it...but...that was my problem...
Old Oct 8, 2003 | 02:47 PM
apick42's Avatar
Your keyless entry module is bad ,sorry to say, but you will have to buy a new one or get an alarm with keyless entry.
Old Oct 8, 2003 | 03:41 PM
multicar's Avatar
Possibly switch contacts in the door jams or at the rear hatch latch. If not, I think the alarm system is integrated into the body control module located by the passenger kick panel.
Doug
Old Oct 8, 2003 | 03:49 PM
turbo_Z's Avatar
what happens if you lock the doors w/o the key fob so as to not set the alarm?
the vibration sensor for your alarm system(granted your car is like mine) is on the pass. side fender behind the plastic side molding. you must remove the same molding when you get to your spare tire if the helps.
Old Oct 9, 2003 | 12:44 AM
Oxygen454's Avatar
Hey,
I opended up the sensor a few days ago and it was full of water. So yeah I dried it out and it should work now. Thanks for the help!
DirtyDan
Sep 28, 2009 10:27 AM
Rich_z28
Sep 13, 2002 03:35 PM
BAD 97 WS-6
Sep 11, 2002 01:45 AM
Firebird9463
Aug 5, 2002 08:17 PM
dreamer1q
Jul 24, 2002 04:39 PM
