Keyed Crank Hub
Old Apr 7, 2007 | 04:06 PM
  #16
The Engineer's Avatar
Actually, the front end of LT engines are internally balanced, therefore LT engines use a "damper" and not a balancer.
Also, the hub doen't have to be keyed on an LT1, however, it makes sure you keep your mechanical timing reference correct (hub can't slip).
Here is a photo of the Jeg's LT1 damper (under-drive), however, you can't see the hub. Both are very high quality items and SFI approved.
WD
Old Apr 8, 2007 | 12:56 AM
  #17
dannyum89's Avatar
Okay... thats very nice but nobody has a part number for anything. I just need a keyed hub. As stated before Thunderracing isn't an option so please guide me somewhere else. With a part number please.
Old Apr 8, 2007 | 07:06 AM
  #18
lethal93ta's Avatar
I have one for a 93-95 if someone needs one of those I cant help you with your 97. I bought a fluidamper for on mine and it has a keyed hub built right in.
Old Apr 8, 2007 | 07:17 AM
  #19
97WS6Pilot's Avatar
I have a stock keyed hub in the for sale section.
Old Apr 8, 2007 | 08:21 AM
  #20
Everyone has provided you several very good options for a keyed hub. For example; I recommended the keyed Jeg's hub which is a very good item (call Jeg's or look in their catalog). Therefore, I'm not sure why you're still not able to choose a hub???
WD
Old Apr 8, 2007 | 08:47 AM
  #21
dannyum89's Avatar
Thanks but your hub says that its off of a 95. I have a 97 and I can only use the 96 or 97 hubs. As far as what "THE ENGINEER" says. I did call Jeg's and they don't have any in stock just like everyone else. The ship date for it would be May 4th. Sorry man but I can't wait that long.
Old Apr 8, 2007 | 11:10 AM
  #22
AmericanMuscle33's Avatar
dibs. This thread has officially become Extremely Helpful...
Old Apr 8, 2007 | 09:16 PM
  #23
dannyum89's Avatar
LOL Yeah. That was very helpful. NOT!!
Old Apr 8, 2007 | 09:27 PM
  #24
mdenz3's Avatar
Just take your hub to any compitent machine shop(doesn't have to be an automotive machine shop either) and have them put a keyway in it for you. I'd do it for you at my shop if i had the time.
Old Apr 8, 2007 | 09:40 PM
  #25
SS RRR's Avatar
If you're going to whine about the answers given then seek info elsewhere. Why do you feel you need a keyed hub? Because you feel it would be cool to say you have one? I have not yet found one reason why your engine would require one.
Old Apr 8, 2007 | 10:22 PM
  #26
dannyum89's Avatar
The information I was refering to in my so called "whine" is that I don't need a hub from a 95 cause it won't fit. My sig states that I have a 97. Secondly a 396cid expecting to make around 530hp at the crank will likely require a keyed hub. Thank you for telling me that its gonna be a cool part to have because I wouldn't want a hub that isn't cool. Im done with this thread. Thanks anyway guys.
Old Apr 8, 2007 | 10:38 PM
  #27
SS RRR's Avatar
Next time you should address your whine more specifically.
Can you explain why instead of the "just cuz" response?
Old Apr 9, 2007 | 02:12 AM
  #28
F'ing A man...I appreciate you started this thread; as a latent effect I have (most likely) solved my key'd hub woes.
You had half a dozen people go out of their way in an attempt to help you with your problem.
As far as needing a key'd hub, I'll soon have a small parasitic draw called a T-trim...otherwise I wouldn't be bothering with this.
Old Apr 9, 2007 | 04:46 PM
  #29
lethal93ta's Avatar
unless your running a supercharger off the front there is no need for a keyed hub.
Old Apr 9, 2007 | 10:29 PM
  #30
dannyum89's Avatar
Guys. I know your probably all hating me right now and im gonna make it worst. It turns out that the ATI super damper I bought last month has the keyed hub already attached to it. I never really looked at it until today when I called ATI. I gave them the part number of the balancer I bought and they told me the hub should already be bolted to it. I openned the box and a hub suddenly appeared. I am so sorry and embarraced. I really appreciate the help even though I was being a dick. Thanks Guys
mightymouse383
Jul 20, 2016 07:34 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
