Key switch ignition problem
Old Jan 30, 2004 | 03:40 PM
kaoticcamaross's Avatar
I couldn't get the key out of my 95z28 this morning. It was cold and I went and started the car and then took it around campus to the baseball field for practice. Well When I put the car in park and went to turn the keys toward me I wouldn't turn. I thought maybe It not in park so I put it back in drive and then in park again still wouldn't come out. So me being frustrated hit the steering wheel colum and then figured I try one last time to get the key out. It worked. Anyone know whats broken that it won't let my key out?
Old Jan 30, 2004 | 03:50 PM
Lyle A's Avatar
It might just need a little lube. Dry graphite is good for lock assemblies.
Old Jan 30, 2004 | 04:30 PM
so you think lube will fix it??????
Old Jan 30, 2004 | 06:40 PM
If it because the key cylinder is not turning far enough to the lock position, this might help.
Old Jan 30, 2004 | 06:46 PM
yea that sounds more like my problem.
Old Jan 31, 2004 | 10:00 AM
2cub49's Avatar
On my car I had to drop the column and bend back a tang that holds the other end of the cable to the column. It had popped uot and I couldn't get the key out.
liamcg97
Nov 25, 2019 05:55 PM
eazyZ
Mar 1, 2015 07:12 AM
Dzmaro
Jan 25, 2015 10:39 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
