Keepers won't budge.
Old Mar 29, 2004 | 06:18 PM
rpm4lalo's Avatar
Question Keepers won't budge.
I have the Crane 10308-1 kit installed from a previous cam swap.
I have the heads removed from the TA.
I have tried hitting the tops of the retainers with a rubber mallet, then compressing the spring, but the keepers won't budge where I can get them out with a magnet.
I even put some WD-40 where the valve, retainer, and keepers are, then beat on them again before compressing.
The keepers simply slide down with the retainer and valve.
Anyone have any other methods that have worked with stubborn keepers.
Old Mar 29, 2004 | 07:30 PM
rpm4lalo's Avatar
Anyone?
Old Mar 29, 2004 | 07:36 PM
IrocSS85's Avatar
when you say slide down w/the reatainer and valve, what kind of compresser are you using? you need a off the car type that will hold the valve closed while you squeeze down on the retainer. then the valve cant move and the keepers will break free from the retainer. and, how are you hitting on the retainer? I hit on the side of the retainer, not the valve at all. that will help pop it off the keepers which are stuck to the valve also. know what I mean? when the keepers pop free from the retainer, there is a distinct sound difference from when I hit it and it is stil stuck on.
Old Mar 29, 2004 | 07:51 PM
94 CAMRO Z28's Avatar
When I took my springs off for the cam swap I used a deep well socket on top of the retainer and hit the socket pretty hard with a hammer. This enabled me to probably get a more direct hit straight down on the retainer.. They came apart with no problem using this method.
Aaron
Old Apr 1, 2004 | 02:45 PM
rpm4lalo's Avatar
Thank you for the replies guys.
I finally was able to get them loose, by first compressing the spring then using a rubber mallet to hit the valve from the other side of the head.
Old Apr 1, 2004 | 03:02 PM
WS Sick's Avatar
The way I always do it is place a small block of wood under the valve and then strike from the top with a rubber mallet while compressing.
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
