Keep popping out pushrods
Old Dec 23, 2003 | 10:39 PM
  #16
Brandon 95 Z28's Avatar
Are you using the correct length pushrod?? Did you mill the heads or run different head gaskets?? Might want to double check your valvetrain geometry with a pushrod length checker.
Brandon
Old Dec 23, 2003 | 10:57 PM
  #17
Igniter's Avatar
Originally posted by NOMAD
I'm not even sure if they make a S/A Pro Magnum rocker. I know mine weren't and I never specified.
-Shannon
Comp Cams does in fact make both S/A and Non S/A 1.6 Pro Magnum RR. I have S/A without guideplates in mine.
Just FYI
Old Dec 24, 2003 | 08:14 AM
  #18
v7guy's Avatar
I appreciate all the replies, I will make sure upon reassembly I pay attention to the flat part of the roller.
There are ears upon the rocker arms some of them have been damaged though when after some of the pushrods popped out.
But as I mentioned before, most of the time the pushrods aren't bent, it's only happened a couple times that I bent one, but when I did it was severely bent
So when putting it back together, go ahead and get some guideplates just for reassurance (and the damaged ears can't help the situation at this point), tighten it until there is no up and down movement at the pushrods and then tighten the allen head and turn the nut a 1/4 turn, and of course make sure I get some hardened pushrods to go with the guideplates.
The general consensus here is that they are over tightened and this procedure I stated above should solve the problems I am having, is this correct?
Old May 16, 2004 | 05:23 PM
  #19
med_reject's Avatar
i always thought guideplates were a bad idea to use with SA rocker arms??
Old May 16, 2004 | 06:21 PM
  #20
smoknta's Avatar
I always thought you tightened until you have no more up and down movement, then turned the nut 1\4 to preload the lifter. Then tightened the allen head to lock it in place.
Your saying you tightened the allen head, then gave the nut a 1\4 turn. Am i reading that right?
Old May 16, 2004 | 06:37 PM
  #21
TedH's Avatar
Shoebox has pretty good instructions here: http://shbox.com/1/4th_gen_tech1.html
Old May 16, 2004 | 07:10 PM
  #22
Pullngz's Avatar
When you bent that pushrod did you pull the lifter? I bet it got the sh#t beat out of it. might possibly have some lobe damage on the cam also.
I agree with everyone else sounds like they were way to tight. Let us know what you find in there.
Mike
Old May 16, 2004 | 08:50 PM
  #23
dnz28's Avatar
spinning the pushrods is a method thats been around for years, i think you people need to open your minds up there usually is more then one way to do something.
all you do if spin the rod till you got a fair amount of drag and the tighten it up 1/4 to 1/2 a turn depending on the rockers.
Aaront810
Aug 29, 2020 09:34 PM
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
