K&N FIPK filter probs
Old Mar 18, 2003 | 01:39 PM
Twice The Fun's Avatar
has anyone had prolems with their LT1 K&N FIPKs. My filter will never stay onto the boot for more than a day, even with clamps and duct tape, lol. Anny suggestions?
Old Mar 18, 2003 | 01:45 PM
jonaddis84's Avatar
Not that bad, it doesnt go on there very far which sucks, but it stays on fine when its clamped down nice and tight. Clean the surfaces off really good, make sure its on there at least a half inch and crank that pipe clamp on there 5 turns past tight.
Old Mar 18, 2003 | 01:47 PM
DjArcadian's Avatar
They suck. There's really no tip I could recommend aside from just shoving it on. Once you get it shoved on firmly it will never come off but it takes finesse and force to get it on there.
dabear95's Avatar
Ditto!
Take your time and make sure its clean and tight...
Jason
Old Mar 18, 2003 | 02:20 PM
z28Power's Avatar
The only thing I could think is that the contact surface is dirty, or you just haven't gotten it on there ALL the way, correctly and straight. I remember so many times it would seem like it was on there correctly, and then you see that it actually wasn't. I would recommend you just take your time, and tighten the **** on there GOOD.
Old Mar 18, 2003 | 03:05 PM
mtealz's Avatar
Yeah mine fell off one day and i drove around for a day or two until I noticed so now I check every day. To get mine on tight enough I had someone push down on the tube while I pushed the filter on from underneath so I could get as much of the lip on the filter around the tube. Hasnt fallen off since.
Old Mar 18, 2003 | 03:08 PM
my94blackz's Avatar
Where i got mine so tight the rubber is coming through the clamp! I have to have mine tight causer i cut a hole in the bottom letting it jus dangle there.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
colts0455
Sep 11, 2015 06:16 PM
Sep 11, 2015 09:44 AM
