K&n cai
Old Sep 7, 2009 | 01:30 PM
moondance's Avatar
K&n cai
I was wondering something when I saw a picture of it on a 3rd gen car. The K&N CAI goes down into the fender. What if you pulled the long black tube that puts the filter down there off and just attached the filter after the MAF? Would it run worse, better, about the same or just not doable? Thanks in afvance for the info
Old Sep 7, 2009 | 02:12 PM
johnnyb's Avatar
if the filter would fit on the maf it would probably be do-able but you would lose power. the reason the filter is down in the fender area is to pick up cooler, more dense air than it would in the engine compartment; hence the term cold air intake.
Old Sep 7, 2009 | 02:16 PM
moondance's Avatar
Gotcha. I didnt know thats what it actually did. I definitely dont want to loose any power. Too bad in Texas all the air is hot lol.
Old Sep 8, 2009 | 12:57 AM
brianswimmer23's Avatar
not as hott as it is here. i would have done a cai still but the problem is the damn monsoons and all of the flooding around here! dont forget their is also a mod to cut into the air inlet under the stock air filter location.
Old Sep 8, 2009 | 08:35 AM
psychocabbage's Avatar
You sure you saw it on a 3rd get?
Old Sep 8, 2009 | 10:29 AM
moondance's Avatar
yep
Kinglouui
May 26, 2016 11:05 AM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
surreybrad
Aug 10, 2015 09:34 AM
