"K" Member???
Old Apr 23, 2006 | 10:18 PM
n.o.s.kid98's Avatar
"K" Member???
I am looking for a new set of motor mount not just the polyurethane pieces I need the whole thing the steel mount along with the polyurethane bushings I do a search on some web sites and it pulls up "K" member does this member replace everything under the motor does it replace the black piece that the rack and pinion connects to? so I would just keep my "A" arms and put my "A" arms onto theis "K" member???? if someone has picks to show me that would be great any help with this would be apprietiated thank you
Old Apr 23, 2006 | 11:02 PM
sssalah's Avatar
Re: "K" Member???
There you go:
The only reason to go for something like this is to loose some weight. Keep in mind this piece is not as strong as a stock one and it could break from daily driving espesially on bad roads.
Old Apr 24, 2006 | 03:52 PM
Re: "K" Member???
thank you for the pics so I think I will stay with the stock set-up I would like to change my engine mounts but dont want to try prying the old polyuerathne bushings out do you have any tips on prying them out and inserting the new ones or maybe you can point me in the direction of an engine mount that come with the steel bracket and new bushings????
Old Apr 26, 2006 | 02:09 AM
sssalah's Avatar
Re: "K" Member???
The Energy Suspension mounts are poly inserts that uses the stock shells. All that needs to be done is to drill the revits to separate the shells. Another option is to get stock OEM mounts, these are less noisy than the poly mounts, and the come complete with the shell.
Old Apr 26, 2006 | 02:20 AM
Z95m6's Avatar
Re: "K" Member???
After you break in the polys they feel like stock. I'm glad i put in polys all the way around when my motor and tranny was out.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
football4life
Oct 4, 2015 07:48 AM
KYWes
Aug 10, 2015 07:03 PM
