Just wasted $300 on a Opti that didnt fix my problem, now what?
Old Jan 11, 2007 | 04:41 PM
bipolar's Avatar
I have NO SPARK. I just put a new Opti on today and a new coil, now what? PCM?
Old Jan 11, 2007 | 04:55 PM
TobyZ28's Avatar
Icm
Old Jan 11, 2007 | 05:00 PM
Black 97 SS's Avatar
bad fuse?
__________________________________________________ ______________
1997 Camaro SS #1039
full bolt-ons, 4:10 gears, chrome Zr-1 w/BFG KDW
Old Jan 11, 2007 | 05:22 PM
bipolar's Avatar
I actually found a blown "ignition" fuse today under my hood after I put the new Opti in and it didnt work. I thought hey a little fuse made me buy a $300 opti but I changed it and still no spark...What would have made it blow? This all started by having hard starts, then would start and run rough and die, then would not start at all. Dead, no spark. Im checking spark at the plug from the plug wire. How do I know if the coil or opti that I have already changed out are even good. I hate eletrical problems! Pcm? Ignition control module? Dont know what to check or where to start. But I dont like guessing and wasting money. Im on disability and make VERY little money..
full bolt-ons, 4:10 gears, chrome Zr-1 w/BFG KDW[/QUOTE]
Old Jan 11, 2007 | 05:25 PM
95LT1conv's Avatar
have you checked for spark at the coil wire?
Old Jan 11, 2007 | 05:30 PM
Under_Pressure's Avatar
Have you checked the opti harness?
Old Jan 11, 2007 | 05:52 PM
sbca96's Avatar
Could be a problem with the ign module. Anyone live near you with a known
good LT1 powered car that you can borrow parts from to test? I dont think
that the VATS causes no spark, I think it causes no crank. Rarely will an opti
cause a no spark condition, it usually causes an irratic spark condition.
Tom
Old Jan 11, 2007 | 06:05 PM
bipolar's Avatar
Yep..
Old Jan 11, 2007 | 06:55 PM
LT-x7's Avatar
Tom
It's not Vat's.
Vat's will let the car start, run for a few sec then shut off.
Old Jan 11, 2007 | 06:58 PM
95LT1conv's Avatar
Originally Posted by LT-x7
It's not Vat's.
not always. it will shut the injectors down
Old Jan 11, 2007 | 07:10 PM
93BlackTA's Avatar
My money is on the ignition module.....
Old Jan 12, 2007 | 09:44 AM
Critter's Avatar
does it have spark? no: icm, coil, pcm related
yes: is the spark hot enough?
does the coil wire have spark?
make sure the opti harness is plugged in.
we need to know where the spark is stopping!!!
Old Jan 12, 2007 | 01:42 PM
cmroSS97's Avatar
i third the vote for ICM but just a guesstimate Good Luck!! FWIW i just got a faulty GM opti but like stated above opti usually just cause irratic spark.
Old Jan 18, 2007 | 11:30 AM
94jetpilot's Avatar
suggestion from someone whose been there done that.
icm would be the first to check, same problem i had, also make sure its got that di-electric grease, also check the grounding also. i replaced that and a new coil and it fired right up! good luck.
Old Jan 18, 2007 | 02:02 PM
popstoy's Avatar
check wires goiing into plug that connect to the coil sometimes the wire breaks going into the molded plug
