Just Learned I Have a Filled Block. Pros and Cons?
Old Aug 13, 2007 | 09:16 PM
JP95ZM6's Avatar
When installing a new knock sensor today, I failed to get a face full of coolant. Surprised, I tried to stick my finger in the hole. No go. Although I did not specify it, my new block is filled, with a very firm but less than rock-hard light gray material. I could stick a dental pick in about 1/16 inch. Aside from increased dimensional stability, what are the pros & cons of having a filled block in a DD street/strip car. Any drawbacks?
Should block fill be rock-hard?
Does it affect the knock sensor performance?
Reduce cooling?
Old Aug 13, 2007 | 09:24 PM
wrd1972's Avatar
I might be wrong but I have heard of people pouring concrete in the block, why I have no idea.
Old Aug 13, 2007 | 11:35 PM
WS6T3RROR's Avatar
a partial fill shouldnt hurt you any, about the only thing i've ever noticed is a slight increase in oil temps under some fairly extreme driving conditions. basicly all the heat that the engine makes is in the heads and the bottom of the water jacket doesnt do a whole lot besides maybe cool the oil.
Old Aug 14, 2007 | 11:16 PM
JP95ZM6's Avatar
Thanks guys. Another thing I found was that the old sensor was really driven into the fill, crushing and deforming it a bit. Probably not ideal for the KS, as it should load on the threads when torqued, not the end of the probe part. New sensor didn't change anything anyways.....
Old Aug 15, 2007 | 05:21 PM
slingshot's Avatar
Some people run an external oil cooler if the block is filled. Watch the oil temp if you can to determine if you need to do anything.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Jul 17, 2015 02:47 PM
Boss002
Jul 9, 2015 03:33 PM
Jmlcolorado
Jul 4, 2015 08:31 AM
