Just installed SLP CAI
Old Jun 25, 2003 | 04:08 PM
drewstealth's Avatar
I installed it last night. Took me about 2 hrs. The fit was real good. Only problem is that the tube is touching one of the brake lines. Is that a problem? Also i got the filters pretty snug on there. I pulled on them and they didn't come off. But they were pretty hard to tighten down. Has anybody had problems with them falling off? Besides all that it looks great. I can feel a bit better throttle repsonse and it feels a little stronger up top. Well at least i think it does.
Old Jun 25, 2003 | 04:21 PM
94 CAMRO Z28's Avatar
Mine also rests against one of the brake lines, shouldn't be a big problem. I think the filters should be OK but you may want to keep an eye of them. Take a look everytime you get gas or check the oil. I did have one fall off once and it was laying down in the plastic box thats underneath.
Aaron
Old Jun 25, 2003 | 08:55 PM
How am i supposed to check the filters everytime i get gas? The splashguard is covering them up. Was i supposed to leave part of the splashguard off?
Old Jun 25, 2003 | 09:06 PM
bigsteve7's Avatar
Why would you need to check them that often? I would say check them every 3000 miles are so at the most... more like 5000 miles. They ought to stay pretty clean though...
Old Jun 25, 2003 | 09:25 PM
No i meant check them to make sure they didn't fall off. It was hard for me to tighten them down. But when i pulled they didn't come off. I'm supposed to leave all of my spashguards on right?
Old Jun 25, 2003 | 09:26 PM
bigsteve7's Avatar
oh i see, my bad.
Maybe you can not attatch the splash guard all the way leaving a a flexible piece that you can bend back to peek...
Old Jun 25, 2003 | 09:35 PM
Yeah i guess i can just remove part of the splashguard to check everytime. I just don't want it to fall off while driving and be sucking up dirty unfiltered air into the engine.
Old Jun 25, 2003 | 11:17 PM
97TransAm's Avatar
Re: Just installed SLP CAI
I Only problem is that the tube is touching one of the brake lines. Is that a problem?
Installed my SLP CAI last Spring ('02). They also touch the brake line. Horsed around quite a bit, been down to the track a half a dozen times and everything seems fine.
Enjoy!
--ron
Old Jun 26, 2003 | 11:01 AM
Tires_Smokin's Avatar
I just took my driverside splashguard off....if you do..might wanna get a K&N filter cleaner kit. Watch out for water puddles tho. Remember it will dirty quicker.
Old Jun 26, 2003 | 11:27 AM
Bastardcat's Avatar
Mine does not touch the brake line--but it is very close. The filters were a pain to get on for me as well. I wouldn't leave any bolts off the splashguard (to peak) and I definately would not pull the splashguard off altogether. At least with the splashguard on it can catch a filter if it falls off (not to mention all the benefits that come along with keeping your splashguard in place.) It only takes a minute or two if you want to remove a few bolts to check out your filters. You could even tap on the bottom of the splashguard to see if anything is rolling around in there, like a filter. Just my nickle's worth of free advice.
Old Jun 26, 2003 | 03:33 PM
Thanks for the advice bastardcat. I'm gonna leave it on. Like you said it will catch the filter. Also i think if it falls off not as much dirty air will get in there.
97 RedSS
Jun 10, 2003 07:58 PM
Thebeast431
Aug 25, 2002 05:06 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
Thebeast431
Aug 8, 2002 01:39 PM
Z28STYLE23
Aug 4, 2002 03:30 AM
