Just installed Pacesetter LTs... Couple Q's
Old May 15, 2005 | 04:26 PM
Robert95z's Avatar
First, the driver side header is hitting the floor board. Is it better to dent in the floorboard or dent in the pipe more... Or a little of both?
And i'll tell you right now, Pacesetters + ORY + Borla = Some raspy nasty crap. thing is I lost my borla block off plate, where can I get another? Should I put a different system on here? I really cant afford anything like a corsa. How much could I sell my borla for?
Old May 15, 2005 | 05:06 PM
Canuck wita WS6's Avatar
Re: Just installed Pacesetter LTs... Couple Q's
You could try taking it to an exhaust shop and having them heat up the header and bending it down a bit. Just enough so it won't hit the floor when you stomp on the gas and the motor tilts. Or do like you said and dimple the header a bit, as well as the floor board. I really don't think it would hurt flow all that much ( as long as you dont go to crazy with the hammer), if your worried about that.
As far as your Borla goes i'd try to get a small block off plate in it, that should help with the raspyness, although Borla is known for it's raspy sound. If your looking for another system i recommend Hooker. Very deep rumble that screams when you go WOT, without any raspyness, or popping with lts and orp.
Old May 15, 2005 | 05:44 PM
blownbird01's Avatar
Borla sounds much better blocked off. If you are looking for another exhaust, mufflex with spintech sounds awesome!
WildRidez
Mar 27, 2015 08:22 AM
alex5366
Feb 17, 2015 09:07 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
