Just did tb bypass... now what?
well, I'm waiting on my LT4 KM and I just did the tb bypass and actually felt some SOTP gain so I'm lookin for more ideas. Any are welcome, I also took out the screen infront of the MAF so that is done. Other mods are in the sig, waiting for $ to do 1.6rr's and a full valvetrain rebuild for a big cam... anything I should do before it? besides suspension/new tires...
thanks for help!
thanks for help!
you felt a sotp gain from tb bypass? you know that mod doesnt give you power over stock right? it just gives back what a hot tb would have taken away at operating temps. i think maybe you got the placebo affect going on there
http://www.ws6.com/mod-8.htm
i know that but it is not over stock.
take for instance when you first start the car up it is cold right. so you are pulling the engines full hp from stock. now when the tb heats up it starts taking power away because the tb is getting hotter. well the tb bypass keeps the tb from getting hot so basically you are staying at you engines rated hp
so you are saying right now i go out to my car which is cold and diconnect my tb i am going to gain 6 hp right then i think not...also i very seroiusly doubt you are going to feel 6 hp come on lets get real.....it takes up to 20 hp to really feel anything in most engines you figure an a/c comp robs about 20 hp i can barley feel that on my car when my a/c kicks in
no hating here i know it is proven to give some gains. it just makes me laugh when people say they got a sotp from it or they noticed a diff. also the tb will stilll get hot in slow driving it wont cool off until the air starts moving through the tb at faster speeds to cool it so it really only gives you a gain at higher speeds
this is disturbing, I felt a gain in the mid-range 3000-4500 range w/ my headers, 3" exhaust to a cut-out... I dont really care if you dont think I can feel a gain. it has been proven at the site he showed you and many others before that. just go away troll.
Find a used CAI, their fairly cheap. Lose the front sway bar when you go to the track,You'll have to buy new end links when you put it back on, 30 bucks maybe? Pump the front tires up to 40 psi. Take out the extra weight, spare, jack, maybe the back seat and belts. And while your at it make sure the washer solvent bottle is empty. With some sticky tires and some decent air I would think you could cut some low 13's.
I didnt feel any difference myself, but im sure it helped.
