Just brought home my Z28!!!.. heres my story
Ok guys, the deal is final, i finally, after months of waiting, trying to sell my moms car, working overtime i finally bought the Z28!!! All i can say is wow, its such an upgrade from my 94 non-turbo 3000GT. But the day didnt go off without a hitch. First off, as soon as i drove it off the lot and about a mile down the rode, it ran out of gas in the middle of a busy intersection, apparently these cars arent like 3000GT's, in which you can drive around for a day or two with the gas light on, and it still runs fine. The needle was right at the E and i noticed and said ill just wait till the light comes on, BOOM right in the middle of the street it sputtered and shut off, i with the help of a few others, pushed it into a gas station which was right there about 100 feet away. SO, i took it home and it was all fine, everything was working perfect, i parked it at my house and starting checking all the fluids. Everything looked fine to except for when i checked the engine coolant, it looked good, neon green and all, but on the dipstick there was this clumpy brown stuff that came right off, i took a flashlight and looked down the tube and it all looked good to me, there was no more. I was a bit worried could this be oil, let me know, but im extremely happy with the car, its a 94 Z28!!
hey glad to hear you got a Z. there's no gas light in these cars, not on the LT1s anyway. you're lucky you didnt kill your fuel pump, try not to let it go below 1/4 tank, as the fuel pump uses the gas to keep it cool. when my gas guages gets to E, it mean you're almost sucking on fumes. have fun, be safe.]
oh yeah...the brown stuff, might just be sludge in your cooling system, which should be flushed out soon as it might clog your heater core or something. if your oil turns milky then I'd worry.
Congrats on getting the Z...That brown stuff is just build up in the coolant area. Very typical on cars....If it bothers you that much, do a complete flush of the cooling system. You should be good man!
No fuel warning on my 94....but I don't let it get past 1/4. Once you're at 1/4, you're prettymuch empty.....what is weird is I could fill up my tank, and after driving 100 miles, the needle is still pushing past the "Full" mark on the gas gauge. The gas gauges in these cars suck!
No, you're not nuts.... it's true. The f-body tank is trapizoid-shaped, becoming more narrow at the bottom. That's why the fuel gauge is not accurate. So, the rule of thumb is: When your needle indicates 3/4 full, you're really 1/2 full. I always just subtract 1/4 tank from what is indicated.
I remember my Stealth TT - what a great car that was, but what a PITA to keep fixing!
Greg
Greg
First congrats on the Z28.
Since it's used, do a complete flush of your coolant. Charged fluid could accelerate corrosion on the internal parts the fluid flows through.
Also not sure, but do Z28 use the green or orange coolant? My 96 came with orange, and I still use the stuff.
As for gas level, fill it at 1/4 left....the stupid gage is decieving. On mine, I can get out 150 miles before it hits the midway mark..thinking cool, I'm getting great gas mileage...than it plummets to almost empty after another 50 miles.
Else you can zero out your trip and refill against a set mileage. You really don't want to go empty with the fuel injection.
That's something else I forgot to mention. Our cars came originally with orange antifreeze. If someone just poored in green to refill it the two of them react to each other. They make kinda like a sluge or something but it can be harmful to the cooling system and other parts as well. That might of happened with your car. Get the system flushed to clear out any chance of that. Once you refill you can use either green or orange, just not both.
Good rule of thumb on buying a used car; always change all your fluids as soon as possible. You never know when the last time it was done and it is always good preventative maint. Pull your battery out and pull out the overflow reservoir and clean that puppy out when you flush your system. Also, don't forget to bleed the air out of the system when you do.
