Just bought the car, can someone help me out with a few questions??
Hey i just bought a 94 camaro Z28, a couple hours after i took it home my friend, who had a camaro at one time, showed me that you could unbolt the rest of the exhaust from the cat via loosening those two bolts, and have the exhaust come str8 out the cat, its really loud, and it sounds mean as hell, my question is this.. does doing this affect the car in anyway, good, bad. let me know thanx.
Theres an aftermarket part called a "cutout" that you can install right after the cat the will basically do this for you. You can buy a cheap one for $35 that you manually have to open, or get an electric cutout, that you can open/close at the flip of a switch.
is it true that you can lose alot of low-end torque if you completely take off the cat, and just how exactly does backpressure effect the way a car runs, sorry if these questions seem stupid, i just bought the car yesterday after i sold my 3000GT so im trying hard to get to know the whole new lingo on this forum.!!
Originally posted by gamecockfan04
Cat=very restrictive.
Backpressure=myth
Take the cat off! It will only help your performance and HP.
Backpressure=myth
thanks, i actually just reconnected the pipes back, the noise was starting to get annoying, and the smell too, i put it back after someone told me i was risking burning the cat up.
