Just bought this 97 and have questions
Old Sep 7, 2013 | 01:22 AM
  #16
Jeffs1997's Avatar
Re: Just bought this 97 and have questions
Originally Posted by SMok3 Em A11
If you hook the battery or use a hand held to erase codes it very by vehicle but I believe in our cars its like 20-25 miles it has to be driven to reset. At this point if the previous ses codes have not been addressed the ses light should come back on.
Anyone feel free to correct me if I'm off on the mileage.
avid member of LTxtech.com for lt1/lt4 enthusiast...&
HRFbody.com for F body fanatics in the Hampton Roads Virginia area!!
I drove the z28 85 miles and then it passed its obd2 self tests. 30 miles wasn't enough the first time. However my v6 camaro passed after 45 miles. I wouldn't try until you have 50 miles just to avoid a fail on self tests.
Old Sep 7, 2013 | 08:47 AM
  #17
Originally Posted by Jeffs1997
Well it still isn't doing anything odd like the seller told me so I am going to start stripping this car down and begin my V8 conversion. I will probably change head gaskets, intake gaskets, maybe bearings, water pump while the engine is out.
A question though, anyone know what the most likely gearing this car might have? has a automatic. My 97 camaro has a 4wdb 3.42 limited slip rear so was curious if that will work well with this LT1.
Also curious if the dash harness is different from a 6 banger to the v8's?
The Z could have 3.23s or 2.73s. Look for the RPO GU code.
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO (V6)
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
There is little difference in dash harness V6 to V8. More changes are by year.
Sergio
Jan 27, 2016 04:27 PM
95chwagon
Feb 28, 2015 12:02 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Chris Anderson
Jan 27, 2015 08:30 AM
cmdeshon
Dec 27, 2014 10:06 AM
