jimmy 1995 lt1 engine no idle
Old Jun 6, 2003 | 10:13 PM
jimmybodytop's Avatar
the engine had no idle it just stall and hard to start smell fuel a lot and backfire
i just try to adjust the fuel pressure at 40psi with afr aeromotive
and new plugs 41-943 delco ,taylor wire
the engine had no cats,no air pump,and programing with PCMFORLESS
its a caddy 1996 engine with an obd1 pcm from a 4.3 vin w
caprice 1995 and it inside a jimmy 1995 i never make ride ok to get on the road
anyone can help me !!!
Sylvain
Old Jun 6, 2003 | 10:56 PM
No help here
hello need help!!!
Old Jun 7, 2003 | 06:23 AM
slopokrodrigez's Avatar
Only suggestions, no hard answers. Check the basics first, is fuel pressure consistant? Check the vac line on the regulator to be sure it's dry. Double check the wiring to and from the distributor. Pull the plugs and check their condition and do compression while you're there.
check the EGR to see if it is sticking and while you're at it check the IAC. I would also scan it to see if any soft codes are being set and while there, check the signal inputs from sensors like the TPS, MAP and MAF.
Good luck
Old Jun 7, 2003 | 03:09 PM
94FlamdS10Blazr's Avatar
jimmy i answered you over on one of the truck forums, cant remember what I said
calaban
May 18, 2020 06:43 PM
Jan 3, 2015 07:22 PM
joe777107
Dec 1, 2014 09:32 AM
Jul 4, 2005 05:00 PM
