Jet stage 2 chip
Old Jan 21, 2008 | 01:00 PM
z28camaro1090's Avatar
Jet stage 2 chip
I am looking at a Jet Stage 2 chip. Is this the best chip i can get for around $200?
Old Jan 21, 2008 | 01:33 PM
Wild1's Avatar
Why not reprogram your PCM? There are vendors on this board who are in the neighborhood of that price and will custom a program to your car versus a generic performance chip.
Dyno is the best method if that is available. There is a place by my house that will dyno-tune the car at $200 / hr. They usually have wide-band O2s that really dial it in well. The best method.
Old Jan 21, 2008 | 04:28 PM
Mr_Bond's Avatar
That chip will make a good paper weight. Check with some of the vender on the site. They will get you straight.
Old Jan 21, 2008 | 06:47 PM
so what would be your suggestions for the best chip?
Old Jan 21, 2008 | 07:07 PM
Mr_Bond's Avatar
Alvin at http://www.pcmforless.com or Ion at http://madz28.com. I have use both and both are good.
Old Jan 21, 2008 | 07:08 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Check out www.pcmforless.com & www.madtuner.com
A tune may not be of much benefit if you've done nothing more than CAI & Throttle body, but it might. I want to get a tune for my car also. I guess the stock tune causes these cars to run kind of rich. I've read that leaning out the A/F ratio helps a lot at higher rpms. Isn't the 180 degree thermostat stock, or are 93's different?
Old Jan 21, 2008 | 07:11 PM
when i pulled my thermostat out it was a 195.. i have no clue why anyone would put a higher one in.. and my speed shop guy said that 195 was stock.. i was under the impression 180 was tho
Old Jan 21, 2008 | 10:10 PM
revmarc's Avatar
Tested these on a dyno at Roger Vinci's in Orlando 11 years ago, one for a 96 6 speed Z and another on a 94 Impala SS. To say they are junk is an insult to junk everywhere.
GREEN3112
Feb 10, 2019 09:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
92_RS_305
Sep 8, 2015 07:47 PM
Henson071
Aug 4, 2015 09:32 AM
