It's a 95, what kind of scanner?
Old Oct 9, 2005 | 10:41 AM
shawns SS's Avatar
I recently bought a 95Z so it is OBD1, correct? If so can't I check for codes with a jumper wire? If not what brand of scanner should I get?
Old Oct 9, 2005 | 10:49 AM
anaik's Avatar
Re: It's a 95, what kind of scanner?
No paper clip tricks for '94 up. Here's a guide for scanners you can use.
http://members.aol.com/FWForsythePE/HowTo/Scanner.htm
Old Oct 9, 2005 | 11:13 AM
idunno's Avatar
you mean they actually dont have the DIAG output on the connector? Jesus and i find this out right before i was gonna do it to see what code im throwin. I could swear that I saw a DIAG connector in the service manual though.
Rich
Old Oct 9, 2005 | 05:56 PM
Rich
Not sure what you mean. You plug in a scanner to the ALDL and read the codes or monitor the computer.
Old Oct 9, 2005 | 06:10 PM
Dave89IROC's Avatar
http://www.autocheckup.net/Merchant2...tegory_Code=RF
Old Oct 9, 2005 | 07:22 PM
shawns SS's Avatar
Hey Shoebox, what type of scanner do you use?
Old Oct 9, 2005 | 07:31 PM
idunno's Avatar
i was just talking about what shawn and anaik were mentioning...the good old OBD1 paperclip trick. Thats where you connect the diag pin of the connector (at least i think thats the one) to ground and it flashes out the trouble codes through the check engine light. Ive used it many times on my truck, which is a 91, and on other cars. Never had to try it with the TA though, cause i never had a trouble code until right before i went off to school. But i could have sworn that my chilton manual said you could still do it even with the new connector...you just have to ground the right pin. I may be wrong though, its been a LONG time since ive seen that book.
Old Oct 9, 2005 | 09:15 PM
moparman's Avatar
'93 was the last year you could short the terminals out in an F-body. You need a code puller or a scan tool to use on '94 and up.
The refurb Autoxray units are the cheapest scan tools you will find. Autoxray works good.
Old Oct 9, 2005 | 10:26 PM
I have been using an Autoxray for many years. My latest one does OBD-I and II. I also use TTS Datamaster with a laptop on my Z.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
Hal Fisher
Sep 30, 2015 09:03 PM
karpetcm
Sep 29, 2015 10:08 AM
plattted
9
Sep 20, 2015 11:23 AM
