Iridium spark plugs worth it?
Old Mar 24, 2003 | 02:12 PM
93zder's Avatar
Question Iridium spark plugs worth it?
Was wondering if these stand true to what they claim of lasting longer than platinums and firing more power? Or should i go with the TR55's or the stock AC platinum's?
Old Mar 24, 2003 | 03:13 PM
RamAir95TA's Avatar
Absolutely not worth it. $6.00 a plug is ridiculous.
TR55s will work just as fine.
Old Mar 24, 2003 | 03:20 PM
teke184's Avatar
i second the above...i can change plugs 3 times for the price of your set of one iridium...
so they woould have to last 3 times longer to make sense..
and more power...maybe .1 hp...
Old Mar 25, 2003 | 11:26 AM
93zder's Avatar
Thanks guys, TR55's it is then.
Old Mar 25, 2003 | 01:27 PM
xxsaint69x's Avatar
i use Autolite 106...a lot better then the NGKs..the tops DO NOT SCREW ON/OFF!
Old Mar 25, 2003 | 01:53 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I've always used the AC Delco Rapid Fires. Have had no problems.
Chris
Old Mar 25, 2003 | 02:08 PM
snorkelface's Avatar
Question
How about the Bosch Platinum +4's? Anyone have an opinion?
Old Mar 25, 2003 | 02:34 PM
93zder's Avatar
I've heard Bosch Platinums don't work well in our cars - anyone know for sure?
Also, how do the Autolite's work better and why would the tops screw on/off ?
Old Mar 25, 2003 | 02:35 PM
teke184's Avatar
from what i've seen the 4+'s are a waste as well...
Old Mar 25, 2003 | 02:47 PM
EviLBoX's Avatar
Well, I don't consider $6 a plug for paltinum/iridium ridiculous considering how long they last. I'd much rather spend $6 a plug for ones that will last 50,000 miles instead of $2 a plug for ones you replace every 10,000 miles.
Old Mar 25, 2003 | 03:18 PM
Question
Well, how about the Splitfires then? Sorry, I'm just going to be changing plugs in the near future, and only want to do it once.
Old Mar 25, 2003 | 03:52 PM
snake_skinner93's Avatar
i would stay factory and use AC DELCO PLATINUMS. i've never had a problem with them. Splitfires suck, but Bosch's are ok.
Old Mar 26, 2003 | 07:09 AM
93zder's Avatar
So what is the hype with iridium? Does it last even longer than platinum? NGK says the electrode is 25% smaller than the platinum which allows better spark - anyone know if this is true?
Old Mar 26, 2003 | 05:06 PM
93zder's Avatar
ttt
Anyone know?
Old Mar 26, 2003 | 09:56 PM
DiabloZ's Avatar
I have Denso Iridium plugs. I got them off Ebay quite a while back but they were still like $6 each, but that was cheap for them then. They are a really good plug. I just rebuilt the engine and put them back in, they looked great. They ends the wires clip on to do unscrew. I got them because of the milage claims and my ungoddly pain in the butt headers..Plus they said it was what all the import racers were running so I knew I needed some to keep up.
They are supposedly a pretty hot burning plug so it dependes on your engine set up if you want something cooler burning..
